I had to swap speedos over as fuel gauge was not reading correct and noticed on removal the airbag light had been removed and never even noticed it not coming on lol
So fitting new speedo caused air bag error to flash.
On inspection being a phase 2 it does not have an air bag on off switch in the dipping beam panel to the right.
There is the block behind with foam wrapped round as if never used and the fuse panel underneath the steering wheel has no relay in the plug with same wires that the air on off switch i guess would use (next to 2 purple relays then a brown blank plug and then a brown blank plug) not sure if either need a relay inserting but currently there both empty.
The seats have no air bags but wiring looms are under the seats (i do have some with airbags to go in) would them not being plugged to anything cause a fault?
Removing the top glove box there is also an air bag wire there also? Would that also cause a fault?
Any advise be great
V6 Power!Faster I can go the better!
calibra306
