Author Subject: PAS Pump
cdgray
Hi All,
I'm after a PAS pump in good condition.
Mine seems to have seized (pulley doesn't rotate at all) and the aux belt is now very loose, so think this has snapped as a consequence. I will have a proper look in the morning when it's light to confirm.
If someone has one in Bristol that would be ideal, otherwise prices including delivery please.
Chris - Phase 3 Moonstone GTi 6
Posted 13th Apr 2013 at 21:11
clen666
£25 delivered Smile
Team 'unintentional rat look'
Posted 13th Apr 2013 at 21:39
tvrfan007
Thug pudding may have one otherwise I got one you can have for 15 posted.
I'm Si btw Tee hee
Night Blue VW Golf GTD
Posted 13th Apr 2013 at 23:09
cdgray
Thanks for the replies.
Upon inspection this morning when the aux belt was actually off, the PAS pump pulley rotates fine so think the pump is still ok.
The belt is f*cked but not broken as is the pulley on the tensioner (damaged on one edge but still rotates true) so will be replacing those bits first and see if all is good then.
Not sure if the pulley was damaged, which caused the belt slip off or if the belt came off and damaged the pulley as it did because the plastic looks melted. I had been sat in traffic for over an hour before it happened.
Posted 14th Apr 2013 at 17:19
