Author Subject: Noise when i turn right
redworminator
I have a problem with my gti, its whenever i start to turn the steering wheel right when driving i get a droning noise and it sounds like its coming form the n/s front wheel. I've had a brief look underneath and around the wheel and i cant really see anything that is causing it, apart from the drop links are totally shot, but both sides are like this so didn't think this was the cause. There is no sign of any rubbing that i can see either, anyone have any ideas? Thanks
Posted 13th Apr 2013 at 10:08
wheelbearing.
Posted 13th Apr 2013 at 10:15
redworminator
would you say that was a definite? why doesn't it do it when it going straight or turning left?
Posted 13th Apr 2013 at 10:25
the direction of load Smile
Posted 13th Apr 2013 at 10:30
burnout21
Not driveshaft or CV joint? When turning its putting load on that side
redworminator
I don't have a clue really, if it is the bearing how big a job is it?
Posted 13th Apr 2013 at 10:34
you need a press, circlip pliers, and a 35mm hub nut socket as well as a normal toolkit.
Posted 13th Apr 2013 at 10:44
redworminator
do you think it would be easier to get a replacement hub? I have been looking and they are 16 or 18mm, which would mine be? Its a 1999 V.
Posted 13th Apr 2013 at 10:53
most likely 18mm, most used hubs have knackered bearings, I'd just fit a new bearing.
Posted 13th Apr 2013 at 10:59
redworminator
yeah? thats not a job i could do. How long would it take/cost to get a garage to do it? Ive only had the car one day and its quite annoying!
Posted 13th Apr 2013 at 11:02
not long at all, if you can get the hub off yourself and take just that maybe a tenner.
plus cost of bearing of course.
Posted 13th Apr 2013 at 11:11
redworminator
Thanks for your help
Posted 13th Apr 2013 at 11:15
redworminator
i can get a hub locally with warranty but i'm unsure if its the right one 100% The guy was saying about the part number, where would i find this?
Posted 13th Apr 2013 at 14:12
