Author Subject: Fix one issue another appears
rich306
Right, some of you remember me posting up a couple of days ago about my Radiator fan switch not working.
That has now been replaced with another which works but is now causing a peculiar problem.
I've touched nothing else but this sensor so it has to be to do with this.
The engine STOP light comes on faintly when the fan comes on.
At precisely 90degrees the fan comes on, the light wont go out until the fans switch off when the engine cools down.
Ideas? (Switch is a Red Ringed Blue switch).
Richies Project Rallye
jamiek_uk2000 wrote:
- Top Tip!!!
Posted 11th Apr 2013 at 18:53
New or second hand switch ?
Checked your coolant level ?
Posted 11th Apr 2013 at 18:56
I'd unplug the fan housing from the car and check the connections as I bet some are corroded Thumbs up
Posted 11th Apr 2013 at 18:57
rich306
Coolant is fine, would this connection issue be the case when just a couple of days ago before i f**ked up the switch... the whole thing was working fine.
Second hand switch.
- Top Tip!!!
Posted 11th Apr 2013 at 19:00
might be needing a new gauge/warning light sender/switch unit.
Posted 11th Apr 2013 at 19:02
rich306
Welsh pug you were right, changed it for a one out of a DTurbo and she works fine. Fans come on just over 90 now which i'm happy with.
- Top Tip!!!
Posted 11th Apr 2013 at 19:19
top job, I had a look on servicebox and its the same part, warning light should come on at 110c
I think I have the same problem on my 205, scares you a bit doesn't it LOL
Posted 11th Apr 2013 at 19:24
rich306
Yeah you could say that, i just didn't want to leave it showing and then when another issue pops up (more serious) me not to pass it off thinking its to do with the fans. Wink
- Top Tip!!!
Posted 11th Apr 2013 at 22:19
