deaf in 1 eye blind in 1 ear
......307 136bhp daily drive.....
306 rallye stripped out and charged.....
lee_gti6 also known as "the tit".....
stan_306gti6 also known as "stan the dick".......
| Author | Subject: testing coil packs.... |
stilly
Seasoned Pro Location: kent Registered: 13 Mar 2004 Posts: 3,487 Status: Offline |
hi all....how would i go about testing the coil packs to see if they are faulty.....i may have an issue with one of mine, but its an intermitten thing....i have 8 spare, but not sure if any are also faulty....just want to check to make sure any are good...cheers boys and girls...________________________________________ deaf in 1 eye blind in 1 ear ......307 136bhp daily drive..... 306 rallye stripped out and charged..... lee_gti6 also known as "the tit"..... stan_306gti6 also known as "stan the dick"....... |
stan_306gti6
Check the resistance across the terminals would be a good start.Is it a misfire issue or something else? ________________________________________ "Supercharged - 454.1bhp/317.5lb/ft"Peugeot 306 GTi-6 2000 (X), Moonstone |
stilly
a bit of holding back as i low revs pulling away...normally in 2nd and 3rd gear....still goner get a new lambda like you said, but i may as well try 4 other coil packs as i have 8 sitting about doing nothing...________________________________________ deaf in 1 eye blind in 1 ear ......307 136bhp daily drive..... 306 rallye stripped out and charged..... lee_gti6 also known as "the tit"..... stan_306gti6 also known as "stan the dick"....... |
stan_306gti6
Coil packs *usually* break down at higher rpm, not always but usually. ![]() ________________________________________ "Supercharged - 454.1bhp/317.5lb/ft"Peugeot 306 GTi-6 2000 (X), Moonstone |
mike rallye
Seasoned Pro Location: mold Registered: 03 Sep 2008 Posts: 1,618 Status: Offline |
What sort of rpm would you say they break down? The reason i ask is I till got this hesitation fault on idle (but it goes after couple of seconds or if I just touch the throttle), but sometime it hesitation round 2rpm .could this be a coil breaking down? |
stan_306gti6
mike rallye wrote: What sort of rpm would you say they break down? The reason i ask is I till got this hesitation fault on idle (but it goes after couple of seconds or if I just touch the throttle), but sometime it hesitation round 2rpm .could this be a coil breaking down? More than likely the lambda. ![]() ________________________________________ "Supercharged - 454.1bhp/317.5lb/ft"Peugeot 306 GTi-6 2000 (X), Moonstone |
mike rallye
Have fitted new lambda just over a year ago |
Could still be lambda, parts can fail at any time. Especially cheaper pattern parts.________________________________________ R H Davey Welding Supplies. I sell new and used welding equipment in the Hampshire area. I take on welding jobs in the evenings, ally casting repairs are one of my specialities but I can weld pretty much anything. PM me with your requirements.Some of my services: (See my for sale threads) Engine mount/chassis repair Solid Beam Mounts BACK IN PRODUCTION Harness bars |
mike rallye
Ok then i get a new one at the end of the month, what make should i get, bosch? |
Should get it tested first, do you have a friendly mechanic that's got diagnostic tools?________________________________________ R H Davey Welding Supplies. I sell new and used welding equipment in the Hampshire area. I take on welding jobs in the evenings, ally casting repairs are one of my specialities but I can weld pretty much anything. PM me with your requirements.Some of my services: (See my for sale threads) Engine mount/chassis repair Solid Beam Mounts BACK IN PRODUCTION Harness bars |
stan_306gti6
As Jim says, testing it first will be the best option. ![]() If you do need a new one then yes, Bosch is recommended as these are OEM fit. ![]() ________________________________________ "Supercharged - 454.1bhp/317.5lb/ft"Peugeot 306 GTi-6 2000 (X), Moonstone |
stilly
ordered my lambda from sc's....£65 all in and its a bosch one.....happy days________________________________________ deaf in 1 eye blind in 1 ear ......307 136bhp daily drive..... 306 rallye stripped out and charged..... lee_gti6 also known as "the tit"..... stan_306gti6 also known as "stan the dick"....... |
