Cheers,
Nick
p.s. I couldn't butcher the old rack to see as it wasn't mine and was still needed!!
AKA nick on 205gtidrivers.com
| Author | Subject: Inner track rod, p/s side |
pooouk
Regular Location: Belper, Nr Derby Registered: 22 Jun 2009 Posts: 259 Status: Offline |
Has anyone changed the passenger side one of these? The drivers side looks like a piece of p**s to change (pull the rubber bellow off, unscrew the arm and reverse procedure...) But even looking at an old rack off the car, I'm struggling to see how the rubber boot on the p/side comes off and goes back on??? The p/steering ram attaches just inboard of where the joint is and it looks like I need to remove the mounting bolt for the ram...Cheers, Nick p.s. I couldn't butcher the old rack to see as it wasn't mine and was still needed!! ________________________________________ AKA nick on 205gtidrivers.com |
Capt Pedantic Location: Bigend, Wales. Registered: 27 Mar 2007 Posts: 25,868 Status: Offline |
the boot is different on the n/s BJ, it has a steel ring bonded into the inner end next to the outer mounting for the PAS ram, lever this off carefully then its exactly the same as doing the other wise.you dont touch the ram or the inner boot. ________________________________________ need a part number? get on here - http://public.servicebox.peugeot.comBring on the Trumpets. |
pooouk
Cheers for that. So I'm assuming that the ring is scrap after that so will need a cable tie/jubilee clip to re-attach it?Nick ________________________________________ AKA nick on 205gtidrivers.com |
no, just lever carefully and as long as you don't tear it it'll go back on fine.![]() ________________________________________ need a part number? get on here - http://public.servicebox.peugeot.comBring on the Trumpets. |
tvrfan007
Seasoned Pro Location: In the garage Registered: 29 May 2005 Posts: 3,488 Status: Offline |
Not a difficult job at all. ________________________________________ I'm Si btw![]() Night Blue VW Golf GTD Bianca LBSC Rallye - Track/Road Slag Project Thread Sparkling Silver Mini Cooper D - Super Dooper - (The other half's wheels) |
pooouk
Ok, cheers for that. I'll have a go at the w/end.Nick ________________________________________ AKA nick on 205gtidrivers.com |
pooouk
So is the ring split where the p/steering ram post sits? When I looked at the rack yesterday, the metal ring has the post going through it, with no visible joins??Nick ________________________________________ AKA nick on 205gtidrivers.com |
Just pop a small flat screwdriver down the edge of the outer boot, lever it carefully towards the outer joint, work around it so you don't stretch it.the steel part is bonded inside the rubber. ________________________________________ need a part number? get on here - http://public.servicebox.peugeot.comBring on the Trumpets. |
pooouk
Just finished doing this job and it wasn't too bad at all. I had to remove the wishbone so that I could get some stilsons onto the end of the rod, but other than that, it was plain sailing!! I see what you mean with the rubber boot, I was imagining it to slide over the rack like the other side does, but when it popped off it all made sense!!Cheers, Nick ________________________________________ AKA nick on 205gtidrivers.com |
