Author Subject: URGENT - Miles gear rod (s) - London or Brighton
meoldchina
Small miles gear rod keeps popping off
Have put cable tie on but need to drive far tmw
Does anyone have spare clip in / around London / Brighton?
Posted 29th Mar 2013 at 14:15
Use a small split pinThumbs up
Available at any motor factors/halfordsYes
Posted 29th Mar 2013 at 14:23
meoldchina
Thanks mate, will do Thumbs up
Can that act as a permanent solution?
Posted 29th Mar 2013 at 14:52
yeah, not a problem.
Posted 29th Mar 2013 at 16:34
As above, yeah no probsThumbs up
Are you sure the small spring clip is not missing from inside the rod?Dunno
As even without the retaining clip these rods take quite alot of pressure to pop offYes
Posted 29th Mar 2013 at 17:47
Posted 29th Mar 2013 at 17:48
Niall
Ive got one small clip sitting on my strut top thats been there for about a year now because i never got round to fitting it back in lol. Your welcome to it
Posted 29th Mar 2013 at 18:16
meoldchina
Thanks Kev - how would I check the spring clip inside the rod? So there's a clip inside & outside? It is very loose so probably!
I'm planning to buy a load of small spring clips from motor factor then dropping in garage this morning.
D'you reckon they'll understand?
Thanks Niall - I've have grabbed this off you yday but reckon I may need more than one & hopefully the clips I get today will sort it.
Posted 30th Mar 2013 at 11:05
Take the rod off and have a look.
Could be its stuck slightly, so not springing back once ball is in the cup.
Posted 30th Mar 2013 at 11:56
meoldchina
Thanks, will do
Just popeed in Halfords but there is a selection so not sure which one (s) I need!
Posted 30th Mar 2013 at 12:57
meoldchina
* update * Miles sent me a new inner ball joint which has fixed it
Posted 10th Dec 2013 at 21:26
meoldchina wrote:
The spring inside looks broken & exterior clip is missing
I would be looking for a replacement rod,unless miles can get the inner spring clip for you?Dunno
Posted 30th Mar 2013 at 22:21
just replace the rod end if the rest is fine.
Posted 30th Mar 2013 at 23:07
