Author Subject: Gti-6 Cabriolet
Andy_Bee_1
HI all, first post on here so be gentle!
I have just dropped a rebuilt and slightly modded Gti-6 engine from a Phase 2 (S-reg) into my '51 Cabriolet (phase 3)
I bought the whole Gti-6 as a running car, it is sat next to the cabriolet now, so I have all parts available from both.
The cabriolet has a DEI/Viper remote start full top of the range alarm system with it's own immobiliser, so currently mine is bypassed by having the transponder glued in the ignition barrel.
From what I have read elsewhere, I should be able to put the whole Gti-6 engine, loom and ECU in the cab, along with the gti-6 immobiliser and antenna, then glue the gti-6 transponder chip in the barrel to bypass the immobiliser and let my 3rd party alarm do the immobilising.
However when taking out the Cabriolet's immobilser to plug in the Gti-6 one, I notice it is very different - the cab one is about 4 times the size of the Gti-6 one and has 2 plugs both with more pins!
So, err, how do I go about this?
Will my, I believe, standard Gti-6 ECU work without an immobiliser being connected (as the plugs are very different)? Do I need to splice the two immobiliser looms together somehow? Or do I need to get my Gti-6 ECU unlocked / buy one already unlocked and just miss out the whole immobiliser circuit and bits?
Is there anything else the immobiliser unit/box does that I shol dbe concerned about if removing it altogether?
Thanks in advance of your wisdom
Andy_Bee_1
Currently undergoing the knife!
Posted 26th Mar 2013 at 15:28
Andy_Bee_1
Ok, I think I know what is needed now...
Basically I missed the trick with starting the Gti-6 as it was and then disconnecting the ECU while running to do the kind of temporary unlock, which would have done for the transformation into the cab.
So, to do it now I have to swap my ECU, Immobiliser and key chip into another Gti-6 and do exactly that - start it up and disconnect the ECU.
Anyone gonna let me do that around the Midlands area? :-S
Posted 26th Mar 2013 at 20:04
jammamayhew Banned!
Hi !
JAMMA "M44YHW" MAYHEW
LOSE WEIGHT NOW - ASK ME HOW -
NUTRI-FIX
GTi6 LPG, The best of both worlds!
2006: 1997 R reg 306 1.4 Miami - Diablo Red - DEAD
2007: 1999 V reg 306 1.4 Meridian - Diablo Red - SOLD
2007-09: 1998 S reg 306 GTi6 - Diablo Red - DEAD
2009-10: 1998 R reg Corsa 1.2 - Blue - SOLD
2010-13: 2001 Y reg 306 GTi6 LPG - Diablo Red - DEAD
2013 - 2013: 2000 X reg GTi6 LPG - Moonstone Blue - DEAD
2013 - current: 2001 X reg GTi6 LPG - Diablo Red
]FOR SALE[/b]
"I LIVE FOR THE 306"
Posted 26th Mar 2013 at 20:06
mcvite
Welcome to the club mate Thumbs up
http://s1160.photobucket.com/albums/q486/mcvite/
Posted 27th Mar 2013 at 04:15
Puggered
Ahhh a man after my own heart Thumbs up
http://www.306gti6.com/forum/showthread.php?id=148164
pretty much explains it I think.
I went the route of a complete aftermarket mongoose system to control immobilizer alarm and c/l
Posted 27th Mar 2013 at 07:53
Andy_Bee_1
Yep, that is exactly the problem and exactly the resolution I need - but got no Gti-6 to do it in Sad
Unless I can put the engine & ecu in the cabriolet and somehow wire in the immobiliser - then I could unlock it myself, just can't do it with the Phase 3 immobiliser as it's wrong plug and not the car the ecu came from! Crazy
I went for the Viper 5702 remote start LE (long range, not allowed in UK) alarm with full window closure, dual level proximity sensors (for when roof down), an aux for the boot solenoid, and 2 spare aux for controlling the roof (I'm making a one touch roof switch - just 2x 30sec timers)
Hoping it will all be nice when finshed - just keep hitting these hurdles! No
Posted 27th Mar 2013 at 12:25
RetroPug
Welcome. Good luck with this problem.
Get some pictures up? Thumbs up
Posted 27th Mar 2013 at 12:42
Andy_Bee_1
The two to be combined into one:
The engine rebuilt and polished up a bit:
The engine in yesterday:
Posted 27th Mar 2013 at 15:19
RetroPug
Engine looks great!
Posted 27th Mar 2013 at 15:27
mechanical_repairs
Certainly very clean.
Carl
Posted 27th Mar 2013 at 18:41
Andy_Bee_1
Oh here's one of the engine during the rebuild and paint/lacquer etc:
Engine painted Chine blue, sump & ancilliaries painted satin black, cam covers and inlet manifold mirror polished then lacquered with a hint of china blue - looking good I think Thumbs up
Posted 27th Mar 2013 at 20:35
Puggered
Carl
and blue.
the obvious solution is buy one already unlocked or get someone to unlock for you
or a loom change LOL
There's a crowd in germany making one touch modules for pugs, https://www.reinhold-engineering.de ,though they're a bit expensive.
Posted 27th Mar 2013 at 23:55
Andy_Bee_1
Yup, but not for the 306 Cabriolet - as far as I know no-one does one for the 306 cab
It is not a complex computerised input, just an up & down switch - but because the European regulations state a convertible roof cannot just operate on it's own without having safety measures built in, which the 306 cabriolet doesn't, it has to remain a switch that you have to hold up or down for the duration of the roof cycle - makes sense kinda, for example; kid gets finger stuck in it, screams, so you let go!
With a one-touch it would carry on and you might be out of the car, so can't reach it to stop, and even then how do you stop it? thus A&E is your next destination No
Anyway, just 2 timer circuits in-line will do it, with a stop if you press the opposite switch- built one up already, just got to make it plug and play next (so no need to splice loom), then maybe make a few... for some reason they seem to be in demand yet no-one has done it Unsure
Posted 28th Mar 2013 at 00:32
Andy_Bee_1
As I haven't put anything about the car before...
Yes it is very blue, and black - no chrome on this car anymore! lol
Here it is in it's home country - on a short weekend trip to take some "after" photos (oh, and take the kids away of course lol) when I got it back from a full respray:
306 cab meet that I organised, Christmas 2011 - Coventry Transport Museum:
And here it is being the daily family workhorse:
Posted 28th Mar 2013 at 00:48
Puggered
Not just European Regs, Australian design rules also require it, not sure on the US though.
I take it you just used a cpl of 555N timers? if you add some load sensitive resistors in the circuit you can monitor the motor load and use that as the "Finger off" safety.......... just thinkingUnsure
Posted 28th Mar 2013 at 00:51
Andy_Bee_1
Indeed 555's it is - wish I'd thought of using a 556, but I think that has it's issues with separate stops for each "side" of the timer.
The load idea would work if operating the switches directly (like rear windows), but unfortunately all the roof operating switch does as standard is earths two wires to the roof ECU in the boot - one for up, the other for down - so the loadand stage of operation, etc are all just controlled by the roof ECU Sad
What I have done is make the pressing of the switch operate a ~30sec timer, and if you press the opposite direction on the switch it will stop the timer. So a good safety I think - and yes I usually have two kids in the back.
I already have it modified so the roof can operate whilst driving without the handbrake on - and they've never dared touch the switch yet! lol
Posted 28th Mar 2013 at 01:00
Puggered
or for an ultra simplistic one
change the switch for something other than momentary action Thumbs up
although I'm now going to go pull a roof ecu to pieces just to see what can be done LOL
Posted 28th Mar 2013 at 03:03
Andy_Bee_1
Let me know your findings...
Posted 30th Mar 2013 at 08:45
Andy_Bee_1
Had a few head scratching moments working out which sockets on the engine loom went to which switch/sensor!
On the Gti-6 radiator I have a 4 pin plug on the rear of it on the passenger side. I have the same on my cabriolet radiator. Yet we cannot find something to plug into it from either cars loom, engine bay or the fan housing. What is it for and is there supposed to be something connected to it?
On a friends cab he has a plug connected to it, the cable disappears into the fan housing (he has no aircon and only one fan on his car)
Anyway, much thanks to richW the unlocked ECU arrived, a few more bits were replaced (again!), and then she lives:
Posted 5th Apr 2013 at 09:09
