Author Subject: Engine temp gauge drops under full throttle
hsustyle
Picked up a Rallye today and the oil temp gauge drops all the way down when I accelerate with full throttle. It will then climb back up within a couple of seconds on no throttle or part throttle. It sat steadily below 90 and every other gauge works just fine.
Any ideas?
Beef Beyond Belief
Posted 25th Mar 2013 at 16:20
Dodgy instrument cluster or wiring leading from sensor most likely.
Posted 25th Mar 2013 at 16:47
Niall
Gearbox earth i believe. Had a similar issue not long ago on a mates 6.
Clean it and make sure its secure.
Posted 25th Mar 2013 at 18:00
hsustyle
Awesome, will give that a try. Ph3 clocks are a straight swap right?
Beef Beyond Belief
Posted 25th Mar 2013 at 18:27
Pretty sure they are yeh. I would pull the plug off the sensor as its on the front of the sump could get corroded easy. Worth a spray and a clean up then sort all the earths. Could always swap my clocks if it still don't cure it just to see if it fixes.
Posted 25th Mar 2013 at 18:36
hsustyle
I'll try the gearbox earth tomorrow.
Ph3 clocks would look a lot nicer in the Rallye I think.
Beef Beyond Belief
Posted 26th Mar 2013 at 09:59
