Author Subject: Turini wheel bolts
Niall
Got a set of turinis turning up tomorrow and only just realised i havent got a clue what bolts to use! Are they ok with standard cyclone bolts?
I have searched but cant find a answer Sad
Posted 22nd Mar 2013 at 20:19
they use taper bolts, no not standard bolts from a pug alloy wheel.
Posted 22nd Mar 2013 at 20:25
Niall
Ah gay Sad
Posted 22nd Mar 2013 at 20:37
Niall
Well got some today at the total sum of £40 including mcgard lockers Sad
Posted 23rd Mar 2013 at 22:27
Niall
Ok so bought some bolts and got round to fitting the wheels today and the bolts seem to be too long. When they are sitting in the wheel as they would when they are on the car, they measure almost 30mm thread sticking out. Tried tightening it but it was getting tight before the wheel was even close to being tight Sad. There was still thread in the hub so im assuming i could of tightened it further and it was just full of dirt but i dont want to put bolts in that are too long as they will stick out the back of the hub and i dont want them catching on anything. What size bolts am i meant to be using with these?
Posted 24th Mar 2013 at 18:33
guess you bought long bolts for use with spacers, return them and ask for shorter standard length ones.
Posted 24th Mar 2013 at 19:03
scotzman
I think your total thread should be around 30mm so they are way too long if you have 30mm sticking through the wheel.
Posted 24th Mar 2013 at 19:07
Niall
Thing is though the bottom of the tapered hole is only about 2mm away from the face on the wheel. Might just drive over to speedshack at the weekend and try some when im there.
Posted 24th Mar 2013 at 19:27
