got a little fan problem
the left one isnt working, relays changed, right one spins, left one doesnt if i pull off the brown plug
as i bought the 6, the previous owner pointed at a small switch behind the seat heating switches, the cable is connected to the plug on the brown temperature sensor i was talking about above
if i turned this switch on, the high speed fan started, after i rebuild the engine due to a cambelt failure this switch has no functionality anymore, or a bit later, didnt noticed it exactly
in foresight i bought this brown sensor, at normal temperature it has an restistance of 1.655 ohms, the one still plugged in in the car has 1.800 ohms
could this be the error? any hints?
Regards
Gerald
EDIT: AC switch didnt kick any fan in
specter
