Author Subject: Gear lever
markylee
Hi does anybody do an aftermarket or race version of a gear lever as I keep braking the standard ones on my race car. When I say gear lever I mean the base aswell
Posted 17th Mar 2013 at 17:26
gti6girl
Combrake do a stick and base I believe but you have to fabricate something for lift up reverse
I also believe Colin Sattchel is making a set up for the 306
Posted 17th Mar 2013 at 18:05
sam1
Hi, maybe try a solid gear lever from another 306 model instead of the hollow GTi6 ones. If it's a race car, you could remove the reverse gear cable. When changing from fifth to sixth I've found it is nearly impossible to shift into reverse.
Posted 17th Mar 2013 at 20:56
devere
What the hell are you doing to the standard ones to keep breaking them...!?
Posted 17th Mar 2013 at 21:03
markylee
Funny you should say that, I think I've just worked out why I keep braking them. I'm running a silencer box about an inch directly below the gear lever with no heat shield, so I think the heat is cracking the plastic. looks like I'm gonna need another lever, heat shield and exhaust from manifold back. This expence is never ending
Posted 18th Mar 2013 at 21:18
fordygti
I.used a nice looking bike brake lever for a reverse. Clamped it to my gear stick trimed the reverse cable crimp and sheath.
Works a treat. I'll put a picture on my project threat if I get near a proper computer tommorow.
98 onyx black 306 Rallye
58 black Volvo c30 sport
Posted 18th Mar 2013 at 21:21
Plastic?Dunno
So I presume its the base/ball on stick your breakng?Dunno
Compbrake quickshift is a alloy base and steel ballThumbs up
Posted 18th Mar 2013 at 23:18
markylee
cheers mate I'll get on to them
Posted 19th Mar 2013 at 07:25
