Author Subject: help! possible vaccum leak...
valentin
Hi guys
Basically my car idles perfectly but when braking in neutral or turning the wheel the revs rise. Harder I brake the more they go up. Quick blip of the throttle and they go back to normal. What's the likely cause so I can sort it
Posted 9th Mar 2013 at 16:07
swiftyboi006
Try giving the icv a clean with some carb cleaner
Black p3 Love
Posted 9th Mar 2013 at 17:08
valentin
Thanks mate. Did try that. But it seems to not really be an idleing issue. From what I have read vaccum leak would cause my symptoms but its almost impossible to determine where its coming from. Smoke test might help
Posted 9th Mar 2013 at 18:39
More than likely the PAS pressure switch.
Look down the front of the engine between the inlet manifold and the radiator and you will see a blue coloured sensor in the middle of a pipe. Unplug the plug on this sensor, and then see if the symptoms persist. I suspect they may well be cured.
Posted 9th Mar 2013 at 21:19
valentin
OK mate. Wil try late tonight. Take it its safe to drive with it unplugged?
Posted 9th Mar 2013 at 21:23
It's perfectly fine, a lot of people actually run with this unplugged if it goes faulty instead of buying a new one. LOL
Posted 9th Mar 2013 at 21:37
valentin
Cheers pal. Will unplug it before I go pick missus up and see how it goes. Thanks bud
Posted 9th Mar 2013 at 21:40
valentin
Stan. You were spot on mate...thanks again pal
Posted 9th Mar 2013 at 22:51
valentin
Now I sometimes stall. Should I reset the ecu?
Posted 9th Mar 2013 at 22:57
You can try resetting the ECU, however I would recommend cleaning the ICV first (a guide for this can be found in the FAQ section) and then resetting the ECU. This should see you right. Thumbs up
Posted 10th Mar 2013 at 10:28
valentin
Will do. Thanks
Posted 10th Mar 2013 at 14:09
No problem, keep us updated. Thumbs up
Posted 10th Mar 2013 at 15:34
