Author Subject: 1 clunk when accelerating, and 1 when braking
jammapic
Hi all,
I've fitted my A048R semi slicks back on today, and with all the extra grip they give, I've run into a bit of an irritating issue, that said, I did have it once or twice on the other wheels.
If I launch pretty hard, I get a clunk from underneath my feet - 1 knock.. that's it. If I then brake really hard, I get 1 knock. If I set of gently, no knock. It's like something is moving forwards and backwards.
Also, if I launch hard, I get a knock, then brake gently with no knock and launch hard again I still have no knock.
I have vibratechnics pbushes, and powerflex front bushes in the wishbones along with nearly new top mounts, vibratechnics engine mounts and a welded up (and substantially stronger!) top engine mount along with brand new track rod ends and rose jointed drop links.
I'll get underneath and have a poke about tomorrow, but what do you reckon? A balljoint starting to go?
JP
HDI Engine Tuning / Remapping Services - https://www.facebook.com/dervtech
306 GTi-6 Track Car - 200+ hp all N/A!
306 DTurbo Track beasty - 209.9hp - RIP
Posted 6th Mar 2013 at 18:33
swiftyboi006
Check the top mount for movement i had this on my p1
Black p3 Love
Posted 6th Mar 2013 at 18:56
my track car was like that, was nearside balljoint. thought it was wheelbearing at first. could also jam a chock behind the engine mounting and wedge inbetween the cradle, see if it's moving a bit, but i doubt it's that
Posted 6th Mar 2013 at 19:06
jammapic
I have had the top mounts loose before, but yes checked that and not the problem.
JP
Posted 6th Mar 2013 at 19:07
any play in wheel? mine felt like wheelbearing at first but turned out to be balljoint
Posted 6th Mar 2013 at 19:24
jammapic
No play that I can notice... I suspect I'm not strong enough to make it do it's 1 clunk as I have to set off pretty hard or brake like a loon....
Posted 6th Mar 2013 at 20:30
Check subframe bolts are tightThumbs up
Also do a tightness check on everything thats been replaced.
Check ARB is central too, mine was not and wishbone used to touch it as it moved up/downWink
Posted 6th Mar 2013 at 20:55
dendle89
Also happened to me ! bloody annoying it was
Team 6 Cylinders
Posted 6th Mar 2013 at 21:01
JWP EFi
Turbo Legend!
i had exact same problem when i fitted my hard poly wishbone bushes, only did it at very low speed
and going from reverse to forward or when very lightly braking. i put my car up on a 4 post ramp
and got someone to drive it - couldnt see anything at all. after a couple of weeks the noise got worse
turned out to be a loose subframe!
Posted 6th Mar 2013 at 21:14
footah212
I had something similar , it turned out the nut at the top of the strut needed tightened by about 1/8 of a turn
Phase 2 Blaze GTi6
PS3 - Black Ops 2
Posted 19th Mar 2013 at 22:07
aaron6
Check the exhaust isnt just catching the subframe. Mine did this. Looked like it should clear but when the engine moved it hit. Worth a look for sure.
Posted 20th Mar 2013 at 11:19
iplay
snapped spring, brake mounting bolts?
Posted 20th Mar 2013 at 21:18
gti6girl
Another vote for down pipe on the subframe.
Posted 20th Mar 2013 at 21:29
craig-gti6
Another vote for down pipe hitting subframe. I had the exact same problem, it sounded like the noise was coming from the drivers side and I was thinking it was probably the top mount. Anyway the other day I was sorting my exhaust out as it was on the p**s and I noticed the down pipe was quite close to the subframe. Since I sorted my exhaust I haven't had any more of those horrible clunking noises. Thank god, it was doing my head in
Posted 21st Mar 2013 at 02:50
jammapic
It was the lower arm front bolt needed nipping up
Posted 21st Mar 2013 at 17:51
jimmyhackers
just had this exact issue for the past while. was the lower arm front bolt that needed tightening like OP's problem.
its was quite strange as the noise sounded like it was coming from the driver side near my feet but the loose bolt was the passenger side.
also it seemed tight already but a little more elbow grease and she tightend about a half turn.
the drivers side was tight and didnt move.
noise is gone. happy days
Posted 6th Jan 2024 at 15:48
