Innes drummond
| Author | Subject: piper cams? |
inzomatic
Regular Location: alloa Registered: 10 Jan 2013 Posts: 157 Status: Offline |
hello again was wondering what the advantage of having piper cams fitted to my 6 is? im pretty new to this and trying to gain an insight and some info on my pug which i havent had for long so apologies for being clueless________________________________________ Innes drummond |
ed_doe
Regular Location: Milford Registered: 26 Aug 2009 Posts: 255 Status: Offline |
Depending on your application, cams can provide different lift and 'duration', that is how far the valves open, and how long they open for. Most ordinary cars have cams set up to allow decent midrange torque often at the expense of high end power. The compromise on an n/a engine is that when you cam it, unless you really know what you're doing and spend a fair old bit, you invariably end up pushing the power band way up the Rev band, and sacrificing a lot of the low end and midrange torque inthe process. This on its own makes the car harder to drive daily unless you're always always interested in the right gear to keep the engine on the boil.Essentially though a set of cams mild enough to fit in a stock engine will deliver probably 15hp more at the expense of a little midrange. But if properly mapped you probably won't notice the reduction in midrange... ________________________________________ '97 Black Dturbo 110,000miles: SOLD'99 Ph3 Diablo Gti6 108k RIP '93 106 1.5n/a d: daily hack YAAAAAWN '00 Ph3 Astor GTi6 117k |
And I have a nice set going fairly cheap |
ed_doe
Haha in with the self plug ![]() ________________________________________ '97 Black Dturbo 110,000miles: SOLD'99 Ph3 Diablo Gti6 108k RIP '93 106 1.5n/a d: daily hack YAAAAAWN '00 Ph3 Astor GTi6 117k |
inzomatic
thanks for the info will be gradually asking questions as i go recently had my cylinder head looked at got new head gasket head set and bolts ,new timing belt water pump etc also had head pressure tested and apparently a lot of repairs were done ......HOWEVER noticed when i got it back it was running ruff and could here a tapping got a compression test from a fellow pug driver who is on this forum and found cylinder 3 was at 160 psi with the others being at 220,240 was suggested maybe bent valves although when ive been driving it recently it drives great although still taps i think? i dont have anything to compare it to so dnt know if i should just leave it or is this likely to bite me when i least expect it?________________________________________ Innes drummond |
That's definitely something I'd want to investigate further, compression figures should really be within 10% of eachother.________________________________________ R H Davey Welding Supplies. I sell new and used welding equipment in the Hampshire area. I take on welding jobs in the evenings, ally casting repairs are one of my specialities but I can weld pretty much anything. PM me with your requirements.Some of my services: (See my for sale threads) Engine mount/chassis repair Solid Beam Mounts BACK IN PRODUCTION Harness bars |
JWP EFi
inzomatic wrote: thanks for the info will be gradually asking questions as i go recently had my cylinder head looked at got new head gasket head set and bolts ,new timing belt water pump etc also had head pressure tested and apparently a lot of repairs were done ......HOWEVER noticed when i got it back it was running ruff and could here a tapping got a compression test from a fellow pug driver who is on this forum and found cylinder 3 was at 160 psi with the others being at 220,240 was suggested maybe bent valves although when ive been driving it recently it drives great although still taps i think? i dont have anything to compare it to so dnt know if i should just leave it or is this likely to bite me when i least expect it? It may run like this for a long time but theres a change it will drop a valve which WILL lead to a totally destroyed engine the tapping noise i heard plus the lack of compression certainly means a bent valve or two, they garage who did the job have either cocked the timing up or have accidently bent the valves when they refitted the head. Its a fairly heavy assembly, plus these engines are tilted back by 30 degrees, so easy to damage |
inzomatic
do you still have a reconditioned head for sale seb? because if i sorn my pug also known as "EL GUAPO" id still like to see it through to a finished item ________________________________________ Innes drummond |
stan_306gti6
Yep, sounds like the garage bent a couple of valves when refitting the head, easily done. ![]() ________________________________________ "Supercharged - 454.1bhp/317.5lb/ft"Peugeot 306 GTi-6 2000 (X), Moonstone |
inzomatic
how expensive is it to fix?________________________________________ Innes drummond |
JWP EFi
assuming its not been a previous snapper and assuming the valve guides are not damaged then its the cost of another new head gasket and set of bolts, new belt-i'm not keen to retension/reuse a timing belt plus new valves then labour on top.yes i still have a reconditioned head |
inzomatic
how much for the head seb ? seen one on e bay for £100 but dont know if i would trust it ________________________________________ Innes drummond |
stan_306gti6
If you are asking someone to do it for you, it would probably be around a £500-600 bill for cylinder head removal, repair and refitting. ![]() ________________________________________ "Supercharged - 454.1bhp/317.5lb/ft"Peugeot 306 GTi-6 2000 (X), Moonstone |
fixing yourself given its only just been apart, £10 a valve IIRC, plus £40 a gasket, £15 belt.plus any valve seat cutting IF required, you can re-use the head bolts as long as they are within spec, as they are not stretch type and should have already been replaced. ________________________________________ need a part number? get on here - http://public.servicebox.peugeot.comBring on the Trumpets. |
stan_306gti6
Yeah, if you feel confident to do the repair yourself, you could probably get it done for under £100. However, it's whether or not you feel able to undertake the work.________________________________________ "Supercharged - 454.1bhp/317.5lb/ft"Peugeot 306 GTi-6 2000 (X), Moonstone |
inzomatic
not sure im a stonemason to trade so unless i can hit with a hamner dunno if i would manage would be really good to gain the knowledge of what is required even from joining this forum ive learned things particularly how to avoid being ripped off however i have learned the hard way !! first time ive had a gti so hopefully i can keep my pug alive________________________________________ Innes drummond |
JWP EFi
no offence mate, but to undertake a job like this on a 6 or any vehicle for that matter requires someprevious experience, its all a basic principal but unless you know what your doing then leave it to someone who has relevant experience. |
inzomatic
aye am happy to do that if a plan is put in place ! i like to have a clear idea of how and when something will be done and from my recent dealings with garages ive found things arent always what they seem ________________________________________ Innes drummond |
stan_306gti6
Where exactly are you based? ![]() ________________________________________ "Supercharged - 454.1bhp/317.5lb/ft"Peugeot 306 GTi-6 2000 (X), Moonstone |
inzomatic
central scotland m8 near stirling ________________________________________ Innes drummond |
stan_306gti6
Ok, I would have perhaps taken a look for you if you were closer. ![]() ________________________________________ "Supercharged - 454.1bhp/317.5lb/ft"Peugeot 306 GTi-6 2000 (X), Moonstone |
