Author Subject: Urgent clutch help needed pretty please
fraserd007
On a trackday in 205 gti6 engine be3 mi16 clutch, problem is the clutch has just gone and wont engage but if you pull the clutch arm on the gearbox up it works for a bit then clunks and goes back to not engaging again anyone any ideas and quick fix only ruddy done siting lap. Cheers.
Posted 2nd Mar 2013 at 10:08
check the gearbox bolts.
Posted 2nd Mar 2013 at 10:17
fraserd007
Just tried them all seem good. Cheers.
Posted 2nd Mar 2013 at 10:37
fraserd007
Managed a temp fix by fitting a circlip pin under the g box arm to raise it up till we can drop the box off, anyone any ideas what it could be?
Posted 2nd Mar 2013 at 11:07
JWP EFi
Turbo Legend!
are you getting any weird noises when you try to push the pedal down?
Posted 2nd Mar 2013 at 17:47
