Author Subject: Megasquirt map for xu10j4rs
Ralle
Hi all,
I'm running standard xu10j4rs and thought that anyone have megasquirt map for it?
So i could get it running. Just newbie with mega Roll eyes
Psa cars fanatic
Posted 1st Mar 2013 at 13:35
mattgti6phase2
Why do you need a different map to get it running? Standard management is pretty good.
Team Nile 6 Superman
Team: 40.2 MPG Smile
5 x a 306 owner!
I truely live for the 306 ®
midweek madness Tee hee
Posted 1st Mar 2013 at 14:40
I assume he has some mods he want to get it mapped for, But meaybe wants this so he can drive to get it done?
Posted 1st Mar 2013 at 14:52
Ralle
Yes, i'm thinking that i now install Mega as i already got it. I also have wiring loom for it. After that i start upgrading and tuning original engine.
Thinking throttle bodies, bigger injectors and lifting fuel pressure and so on... Smile
Psa cars fanatic
Posted 1st Mar 2013 at 15:19
mattgti6phase2
So does the engine have modification currently? From what I'm reading you want to install it whilst the engine is standard and then upgrade the engine Dunno
5 x a 306 owner!
Posted 1st Mar 2013 at 17:17
Ralle
Yes its now standard.
Psa cars fanatic
Posted 1st Mar 2013 at 17:21
Don't bother with bigger injectors or higher FPR, it will not give you a single BHP extra.
Posted 1st Mar 2013 at 17:26
mattgti6phase2
So pointless then. With breathing mods and exhaust at best it's only worth a generic map and even then the only improvements made will be to ignition timing and fuel, this will give you a bit of a gain but not a massive amount.
5 x a 306 owner!
Posted 1st Mar 2013 at 17:48
Ralle
Not even with throttle bodies?
Psa cars fanatic
Posted 1st Mar 2013 at 17:51
mattgti6phase2
If you run cams and itb's you will need a standalone ecu to cope with the tuning differences. Massive difference on fuel and air, bigger injectors etc.
5 x a 306 owner!
Posted 1st Mar 2013 at 17:54
NO.
without a proper engine build with new pistons and cams, stock injectors are fine to circa 240 bhp @ 3bar.
Posted 1st Mar 2013 at 18:18
mattgti6phase2
Okies.
5 x a 306 owner!
Posted 1st Mar 2013 at 18:43
