Author Subject: ABS removal.parts needed?
7057sam
Hi guys, stepping up the track car assault on my rallye.just needing some advice about removing it, what parts I needed?
So I things I need: 406 master brake cylinder
Bias valve
Pipe work? ? braided lines
Do I need to relocate the cylinder? Any advice/tips would be great.
Team rallye,built for track
Rallye dead Sad
Secret Team Astor...
Posted 1st Mar 2013 at 00:44
darzmat
you can still use the standard rallye/6 master cylinder,
search for removing abs in the brake section, theres a few posts with some usefull info.
http://www.306gti6.com/forum/showthread.php?id=140612
Posted 1st Mar 2013 at 01:13
Simply some t pieces from a non abs 306, scrapyard only as tthey are nfp, thats all.
Bias valve only required if load compensator removed.
Posted 1st Mar 2013 at 07:28
7057sam
See I don t even now if mine had a load compensator? Was thinking I needing a 406 master cylinder if did nt hav/got rid of the compensator.can I still use a bias valve with the compensator in?
Rallye dead Sad
Posted 1st Mar 2013 at 07:59
Rallye is classed as phase 2, so I guess you do have the brake compensator Sam Yes
Have a look under the rear of the car, on the drivers side of the beam you should see a plate and a bit of flexi hose, if you do not have that, you have EBD controlling it, but this is phase 3 only IIRC.
I need to get this all done on mine, just cant be bothered Laugh
Posted 1st Mar 2013 at 08:08
7057sam
yeah im remove ABS,Power steering,Battery from engine bay.Cant wait till next month to start stripping all the dirty suff of my engine bay and start painting it up Smile
So does the bias valve take over the control of EBC controller.
Rallye dead Sad
Posted 1st Mar 2013 at 13:11
Bias valve just limits the pressure to the rears so you don't end up locking up and spinning constantly. Dunno what the deal with the electronic brake bits are, mine only had ABS.
Posted 1st Mar 2013 at 13:40
7057sam
ok,what pipe work do you need to run the bais valve?
Rallye dead Sad
Posted 1st Mar 2013 at 13:43
Have a look in here.
Posted 1st Mar 2013 at 13:54
Bin the compensatorYes
Run a single line under car to rear with bias valve in, T piece near rear beam with a line to each sideThumbs up
Then a T piece on bulkhead with a line to each front sideSmile
Posted 1st Mar 2013 at 14:29
