Author Subject: Alternator goosed?
clen666
I'm getting a squeal from my alternator, I'm guessing it's the bearings.
I've measured the voltage across the battery when running and it's a steady 14v, but when I increase the electrical load when idling the revs drop quite a bit and nearly stalls, but voltage returns to 14v no problem.
Is it knackered bearings putting added strain on the engine causing the revs to drop so much, or another issue?
Team 'unintentional rat look'
Posted 27th Feb 2013 at 22:24
14.7 normaly when car is running dude ?
Posted 27th Feb 2013 at 23:05
Sure it's not a knackered or loose belt that's slipping?
Posted 28th Feb 2013 at 08:04
Remove the aux belt and manually spin the alternator by hand. It should be smooth and free as you like to turn. If it's difficult to turn, feels rough or makes abnormal noises then it's probably knackered. If not then, it could be a damaged belt or another bearing on that belt circuit which is causing the noise and seizing up placing excess load on the system so when you place more electrical load on the alternator, the whole system struggles to turn.
Posted 28th Feb 2013 at 08:44
