Now having checked the FAQ there is no mention of what relay does what, and indeed i've seen pictures of the fuse box with and without this relay in place... does anyone have any idea as to what this thing controls, is it something not used on a Phase 3 GTi or indeed something important?
I was thinking engine fans (supported by the previous owner, who says it was like that when he got it and was to help with a fan issue according to an auto electrician who inspected it) and having done the usual test by removing the brown plug from the thermostat housing I find that only the left fan spins up at high speed... so presumably something within the control circuit is buggered aswell (this I can troubleshoot using the guides online, i'm suspecting a loose connection and/ or dead fan as it's had the controler replaced previous... apparently)
I've ordered a new fuse box from eBay to be on the safe side, and it looks as if the whole thing comes out easy enough, but I have a few questions.
1. Is the fuse box attached using a loom connector, i'm hoping beyond all it's not a case of removing and attaching each wire individually!
2. How do you remove the relay carrier from the car without the dash coming out (if even possible, again I hope so)
3. What does the missing relay do, and is it likely related to the fan issues?
I'm at a loss here so any help would be MUCH appreciated.
matthew_eames
- (The other half's wheels)
