looking at a nice intercooler and want to run boost pipe under the inlet manifold
| Author | Subject: pas relocation |
JWP EFi
whats involved/needed to move pas pump down where air con compressor normally lives?looking at a nice intercooler and want to run boost pipe under the inlet manifold |
A relocation bracket and associated plumbing from Rich_W is normally the way to go.________________________________________ R H Davey Welding Supplies. I sell new and used welding equipment in the Hampshire area. I take on welding jobs in the evenings, ally casting repairs are one of my specialities but I can weld pretty much anything. PM me with your requirements.Some of my services: (See my for sale threads) Engine mount/chassis repair Solid Beam Mounts BACK IN PRODUCTION Harness bars |
JWP EFi
ok. is he still doing the relocate kit? |
He still does the lot as far as I'm aware, try PMing him ________________________________________ R H Davey Welding Supplies. I sell new and used welding equipment in the Hampshire area. I take on welding jobs in the evenings, ally casting repairs are one of my specialities but I can weld pretty much anything. PM me with your requirements.Some of my services: (See my for sale threads) Engine mount/chassis repair Solid Beam Mounts BACK IN PRODUCTION Harness bars |
smegal
As above. Rich_W, Carl or even spoox will do them. ________________________________________ Ex SC-6Now in a Megane R26 |
S16 or 8v xsi non aircon setup, lighter than setups mentioned and cheaper.________________________________________ need a part number? get on here - http://public.servicebox.peugeot.comBring on the Trumpets. |
Seasoned Pro Location: Southwark Registered: 18 Jul 2010 Posts: 4,865 Status: Offline |
So on a S16 the PAS pump is where the AC is on a GTi-6??________________________________________ Ex- Phase 3 China GTi-6 T-Reg |
if its a non ac S16 yes.________________________________________ need a part number? get on here - http://public.servicebox.peugeot.comBring on the Trumpets. |
Lighter you say, I assume its usefully so? I always enjoy i lighter option if possible. I assume this wouldnt prevent you running a sc kit for whatever reason if you decided to go for the s16 option rather than the pas relocation kit that comes with he charger? ________________________________________ Ex- Phase 3 China GTi-6 T-Reg |
You wouldn't be able to use it with a Lynx/Rotrex SC bracket bracket, its significantly smaller.![]() ![]() ________________________________________ need a part number? get on here - http://public.servicebox.peugeot.comBring on the Trumpets. |
JWP EFi
welshpug - could i use the above but the ph1 8v xsi version? and could i reuse my GTI6 alternator,pas pump and crank pulley?, iirc using the 6 pulley with all those bits doesn't allow the belt to run true |
JWP EFi
T99PUG wrote: welshpug - could i use the above but the ph1 8v xsi version? and could i reuse my GTI6 alternator, pas pump and crank pulley?, iirc using the 6 pulley with all those bits doesn't allow the belt to run true ...ive just had a think about this and answered my own question lol - pas pump pulley wont be in line with crank pulley think alternator will have same problem so i'm gonna need S16 bracket or 8v XSi (if its the same), alternator and pas pump plus tensioner and pipework alterations |
crank pulley lines up just fine.________________________________________ need a part number? get on here - http://public.servicebox.peugeot.comBring on the Trumpets. |
JWP EFi
Mei - have you still got spare S16 kicking about? |
yup________________________________________ need a part number? get on here - http://public.servicebox.peugeot.comBring on the Trumpets. |
vts_tibi
Seasoned Pro Location: Nuneaton Registered: 27 Apr 2007 Posts: 1,194 Status: Offline |
Can't we fit the GTI6 alternator and PAS pump using the S16 bracket? Could cost a fortune buying an alternator and a pump from the scrappy here...________________________________________ VTSbest 60' : 2.272 best 1/8 ET : 9.375 @ 74.42mph best 1/4 ET: 14.603 @ 97.047mph Team Trackday™ |
JWP EFi
welshpug! wrote: yup does it have the bracket i need? Vts - i'm pretty sure the mountings are diffrent plus the pulley offsets are different |
pulley offsets are the same, however the alternator brackets are different, your best bet is to get the complete setup, however I;m sure the gti6 pump could be used.I'm not sure yet what I'm doing with the ancillaries, but the engine is up for grabs. ________________________________________ need a part number? get on here - http://public.servicebox.peugeot.comBring on the Trumpets. |
JWP EFi
my work mate is looking for an S16, only really needs head and couple other bits but would be happy to buy a bare engine, ie, no manifolds. How much you after? Pm'd you a wee while ago but no reply |
miles
The Alt is different, the S16 bracket hit's the Alloy sump as the S16 engine's had a Tin sump (Without AC) PAS pump will fit either thou but I would not use the S16 pump as the pulley is too large________________________________________ 306 Rallye Sptint/Race Car, 205 CTI 1.9 8v to name a fewRoad, Track and Race/Rally car preparation to your personal requirements, Full Workshop & Diagnostic Facilities New and Second parts, from Plugs to Turbo's We now also carry out Routine Servicing www.pugracing.com & FB Page, https://www.facebook.com/PugRacing Ebay; http://stores.ebay.co.uk/Pug-Racing-Shop 2012/2013/2014/2019 Class Winners at Gurston Down Speed Hillclimb & Joint overall, Class record too along the way, |
JWP EFi
looks like its gonna have to be a richw kit or just do away with the power steering, as i had my ally sump fitted with an oil drain fitting |
easy fix![]() ________________________________________ need a part number? get on here - http://public.servicebox.peugeot.comBring on the Trumpets. |
JWP EFi
mei, as in cut off air con pump lugs on sump? |
