Author Subject: Locating correct length bolts
phil b
Looking into putting my clones back on the 6 when she's up n running, with the use of 10mm hubcentrics to fit over brakes... Anyone got the suppliers or part numbers of bolts??? Done a search no answers to most of these type of threads.... Which is weird tbh Dunno
'97 PH1 'Sigma Blue' 306 GTI 6 project 'Tooters'
194.2bhp 127.6 dB
'96 PH1 'Black Noir' 306 DTurbo (project in permenant storage)
'94 300tdi LR Discovery (project gone dead and buried)
'99 td5 LR Discovery 2 (trailer tug and family bus) project 'in the garage getting chassis welded' (again)
The 6 can go fast, the disco can go anywhere
Built: 9 January 1997 - that's a Thursday
Skip Brown cars: tarporley Cheshire Tel: 01829 720492
add me --> philbrindley85@hotmail.com
TEAM: Snapper Sad
Posted 22nd Feb 2013 at 09:39
You might find you can run standard bolts?Dunno
Stick the wheel on with the spacer and have a look at rear of drive flange to see if the bolt is into the flange far enoughThumbs up
Posted 22nd Feb 2013 at 15:40
pugheaven
At a guess you will need 10mm longer bolts as your adding 10mm extra material!
Posted 22nd Feb 2013 at 16:01
phil b
Yeah just wondering what current users have used..... If there are any pug alloy bolts that will do the job
194.2bhp 127.6 dB
TEAM: Snapper Sad
Posted 22nd Feb 2013 at 17:36
Not if you've got 10mm sticking out of the rear of drive flange with standard bolts and no spacersThumbs up
Pretty sure standard bolts stick out of the rear of the drive flange,just depends on how far,so easiest thing to do is try themWink
Posted 22nd Feb 2013 at 18:29
beez_neez_gt
Try Rally Design, they have a selection of short and long bolts with the M12 1.25 thread type.
Pug fee`ver,
Pick a Bogey, buy a Pug.
Posted 22nd Feb 2013 at 19:19
24seven
You will definitely not be able to run the standard bolts with 10mm spacers. They might bite and tighten up, but you definitely won't be using all the thread available on the hub and at the very least you want to be using all of it, which is probably why standard bolts may stick out the back a little - deliberately! You want bolts that are 10mm longer than standard or if you're feeling plush go for a stud & nut setup.
Posted 22nd Feb 2013 at 21:07
As above, I wouldnt f**k about with how my wheels are held onto my car, this s**t should be done properly
Posted 22nd Feb 2013 at 21:14
pugheaven
Rule of thumb is 3 threads protruding! You might get away with using 407 flat faced bolts but iirc they are only 5mm longer!
Have you tried ur cyclones over the brakes with out spacers as I believe another forum member said they fitted?
Posted 22nd Feb 2013 at 21:36
phil b
Will try when I get my steering rack on, subframes back on now so happy days depends how tight they are....
194.2bhp 127.6 dB
TEAM: Snapper Sad
Posted 22nd Feb 2013 at 23:53
daver6
which brake setup do you have?
Wishbone Polybushes available
Posted 23rd Feb 2013 at 07:20
JWP EFi
Turbo Legend!
wilwoods by the sound of it
Posted 23rd Feb 2013 at 20:59
