.any ideas ? ________________________________________
darrenevansbianca white rallye t706wox
| Author | Subject: heater |
dazzy6
Newbie Location: betws y coed Registered: 18 Jan 2013 Posts: 28 Status: Offline |
Heater only works on number 4 in my rallye but nothing comes out of the vents . Hope the matrix hasnt gone .any ideas ? ________________________________________ darrenevansbianca white rallye t706wox |
Yeah, check it over ![]() Are the pipes connected, are the cables attached to the knobs, does the blower fan work if you give it 12v directly etc. ________________________________________ need a part number? get on here - http://public.servicebox.peugeot.comBring on the Trumpets. |
jimmyhackers
Seasoned Pro Location: birmingham Registered: 14 Jun 2011 Posts: 1,302 Status: Offline |
try bleeding your heater matrix with the little thumb screw in your engine bay where the pipe goes through the firewall.basically with you engine running, open it untill water comes out, then close. if water came out straight away your matrix didnt need bleeding and this wasnt the problem. other than that do as mentioned above, check for loose wires and wayward connections ________________________________________ the world is changed by people in sheds |
