Author Subject: ARP's
JWP EFi
Turbo Legend!
Are ARP rod bolts the stretch type? can they be reused?
Hopfully be building up my new engine very soon and as its a very experimental build i may have to reuse the ARP's
should things go wrong
Also does the same tightening/torque procedure apply for these
Posted 19th Feb 2013 at 20:29
Rod bolts or head studs?
Posted 19th Feb 2013 at 20:38
JWP EFi
Turbo Legend!
Rod bolts mate, infact - same for head studs, out of curiousity. will definately be using rod bolts though
Posted 19th Feb 2013 at 20:40
You certainly need to use "ARP Lube" on the threads of the bolts, I can tell you that. Yes
As for the same tightening torques, I honestly can't remember off the top of my head. Doh
Posted 19th Feb 2013 at 20:41
JWP EFi
Turbo Legend!
ok mate. i heard you need a special socket to torque them, is this true?
Posted 19th Feb 2013 at 20:43
Rod bolts and head studs can be torqued multiple times. Can't remember how many, might be 6 but I can't remember for sure, but I doubt you'll have them on and off even that many times. As for the socket you just need an ordinary 12 point or bi-hex socket.
Posted 19th Feb 2013 at 21:57
pete_rallye
The one's I used can be torqued multiple times until they have stretched beyond a certain point. Unfortunately you have to measure them as new to be able to tell when they have stretched past there limit, as I bought the engine second hand I have no idea what they were as new! Ideally use a stretch gauge rather than a torque wrench when tightening them up too,bit expensive for a single use though!
Lap of the 'ring
Posted 19th Feb 2013 at 22:13
JWP EFi
Turbo Legend!
Thats good enough for me, cheers guys
Posted 19th Feb 2013 at 22:15
