Author Subject: Rear brakes
blandy
Long story short my rear beam is knackered and upon removing today I cannot undo one single brake line as they are heavily corroded and the brake compensator (on right hand side of beam??) is also seized solid which is possibly why I can still turn one wheel when pressing the pedal?
Can I get new lines from pug or is it better to make new? If so what size are the fittings/pipe as can get hold of a flaring tool
Posted 17th Feb 2013 at 18:17
miles
Most are M10x1 male and female, the bias valve I think is M12x1 (Been a while)
But I would ditch the std set up now your there and get a single line to the back but would mean killing the ABS as well thou, use a adjustable valve then
www.pugracing.com
Posted 17th Feb 2013 at 19:11
As above, seeing as its a track car bin all the abs and make up new lines from mc to brakesThumbs up
Posted 17th Feb 2013 at 19:37
blandy
is that good for mot though as still staying road legal for driving to and from track days at least for time being anyhow
Posted 17th Feb 2013 at 19:48
Be fine aslong as you remove ABS totally including warning light in dashYes
Save some weight and make it neater under the bonnet with more spaceThumbs up
If your keen you could strip all the related wiring/relays etc from your loom tooBig grin
Posted 17th Feb 2013 at 21:27
blandy
Cool thanks will leave the wiring for bit as only just put dash back in after stripping a load of wiring last week
Posted 17th Feb 2013 at 21:57
You can change a beam without undoing any brake pipe connections at all. It's a bit of a fiddle but before i replaced my rear callipers due to broken nipples I had to do it last year. But teh if it's a track car then remove the lot and re-do with a valve Wink.
Posted 17th Feb 2013 at 22:49
the flaring tools are cheap from like machine mart
Posted 18th Feb 2013 at 16:24
easy enough to make up anyway with the std copper pipe and some m10 unions etc
blandy
Will pick up a tool this week. Are they m10 in the calipers as well
Posted 18th Feb 2013 at 17:33
daver6
So I can't just ditch the compensator and fit a bias valve and also retain my ABS?Dunno
Wishbone Polybushes available
Posted 18th Feb 2013 at 22:34
You've got two brake lines running down the car, so would need a bias valve on each line to retain abs I'm pretty sureDunno
Posted 18th Feb 2013 at 22:52
daver6
Aye, good point Kev!
Posted 19th Feb 2013 at 15:19
