Author Subject: Gti6 block- s16 head
tarret
Does anyone know if the gti6 block/bottom end fit direct to the s16 cylinder head?
Posted 16th Feb 2013 at 21:45
mr swampy s16
**BAD SELLER**
Nope
Well at least you can't do it the other way around as the oil and water ways don't line up.
Posted 16th Feb 2013 at 21:48
JWP EFi
Turbo Legend!
the oil/water ways 100% do line up
Posted 16th Feb 2013 at 21:50
tarret
Lol so they do but don't :/ lol
Posted 16th Feb 2013 at 21:55
Mrs wampy is talking bo***cks.
However it is not advisable as you would lose compression with an s16 head, of course if you drop s16 pistont and rods in or aftermarket on gti6 rods then all good, other than oil issues.
Posted 16th Feb 2013 at 22:06
tarret
Ok that's cool Smile cheers guys
Posted 16th Feb 2013 at 22:28
What are the oil issues Mei?
Posted 16th Feb 2013 at 22:32
Its an MI16 with a cast steel block, so same oil issues as those, just not quite so bad, apparently.
Though I have two dead ones, and am running a gti6...
Posted 16th Feb 2013 at 23:01
The S16 head on a XU10 block is a good combo though, after compression has been corrected of course?
Posted 16th Feb 2013 at 23:04
S16 IS an xu10 LOL
Posted 16th Feb 2013 at 23:14
You know what I meant, cock Thumbs up
XU10J4RS then...
Posted 16th Feb 2013 at 23:19
elpatron
What compression ratio does this combo give?
Posted 6th Jul 2013 at 18:19
tarret
Would of thought it'll be the same
Posted 6th Jul 2013 at 19:02
Nope, as the head chamber is a different volume, also lower comp as std.
Posted 7th Jul 2013 at 08:42
elpatron
so this would be lower comp than the original s16 cr of 10.4?
Posted 8th Jul 2013 at 23:06
if bolted over RFS pistons yes.
its a good head but flawed, the main reason the later 16v XU's are quite different, and then the EW an evolution of the same later type head in essence.
Posted 8th Jul 2013 at 23:34
beez_neez_gt
Why bother then, spend your time fitting ITB's Smile
Pug fee`ver,
Pick a Bogey, buy a Pug.
Posted 8th Jul 2013 at 23:40
elpatron
The thing is when i get forged pistons and rods from a rfs what cr would i get with s16 head say 12.2 wossner pistons?
Will be fitted with kentcams pt2002. But I think that a cr of 12.2 would be a bit high for such cams would be better around 11.0 to 11.5 i think
Posted 9th Jul 2013 at 08:39
elpatron
ITB would be great but here in switzerland impossible to get these immatriculated. So i have to stay with mods that are not so much visible to the eye Thumbs up
Posted 9th Jul 2013 at 08:38
92mm crank, custom long rods (160+), 87 mm pistons, forget cheap stuff like pec and wossner, it is worth saving more and getting the likes of cp omega or similar pistons and farndon or carillo rods.
That should get you over 200 on mild cams quite easily and be very reliable.
Use the rfs inlet.
Posted 9th Jul 2013 at 13:35
elpatron
Use the rfs inlet.
Is it possible to map the standard ecu for such an application or not?
Posted 9th Jul 2013 at 17:28
Over here it is, you'd need to look into whether you can find anyone in your country/area that can, it's a BOSCH MP 5.2 on the RFY iirc..
Posted 9th Jul 2013 at 18:10
elpatron
So a build with such a crank would give 88mm, what conrods would be necessary with this crank does this work with xu10j4rs spec rods and wossner high comp pistons?
http://www.ebay.co.uk/itm/CITROEN-PEUGOET-1-9d-Crankshaft-std-size-XUD9-engine-code-/160786842827#ht_1135wt_1382
Posted 9th Jul 2013 at 19:43
it would not work with std spec rods+pistons of course, given the extra 1mm in height @ TDC
Posted 9th Jul 2013 at 20:01
elpatron
so the easiest version so far would still be a build with standard rfs spec rods with forged wossner high comp pistons. Straight fit only problem with the high compression ratio of 12.2 of the wossner pistons? but given the s16 head would still be a bit lower than 12.2 without machining because of the head design the s16 has.
what would be a good cr for kentcams pt2002?
If it matters I use this car as a daily driver.
Posted 9th Jul 2013 at 20:15
