Author Subject: Advice for coilover springs
orso
Can you advice what coilover springs (lbs and height) I need for the following configuration:
Front: Gaz Gold coilovers
Rear: Gaz Gold
Standard ARB (24mm)
25mm torsion bars
The car will be used only on track. I know that people use 400+ lbs springs with bigger ARB but my case is a little bit different as the ARB is a standard one.
Posted 15th Feb 2013 at 09:47
I'm not sure you need 400lb springs. I ran 280lb on both 2L and V6 engines and it was ok. The larger rear arb does make a massive difference. Get one if you can.
The car is a GTi6?
Posted 15th Feb 2013 at 12:14
pugheaven
The spring rate is meant to match the spring rate of the torsion bars not the anti roll bar
Posted 15th Feb 2013 at 12:23
orso
The car is GTI6
Posted 15th Feb 2013 at 14:30
