displaying posts 26 to 50 of 114
Pages (5): 1 [2] 3 .. last
Author Subject: Wössner Conrods
Oh crap, really?
So what pistons actually get your seal of approval?
Posted 30th Mar 2013 at 16:00
clen666
I seem to remember Sandy using JE pistons in a build, but could be wrong
Team 'unintentional rat look'
Posted 30th Mar 2013 at 16:08
Hmm
I'm running Wossner pistons and they have been in my engine since 2010...Yes
I hope mine stay in one piece. LOL
Posted 30th Mar 2013 at 16:38
clen666
Ash is running wossner and pec, does anyone know if he's had any issues when racing?
Posted 30th Mar 2013 at 16:52
Not as far as I'm aware. Smile
Posted 30th Mar 2013 at 17:16
Sandy uses a few different sources depending on what he needs and what's available, CP and Omega pistons and Carillo or Farndon rods.
Carillo Rod bolts too, not ARP.
Posted 30th Mar 2013 at 17:26
stan_306gti6 wrote:
Hmm
and just how long has it not turned a wheel...
stan_306gti6 wrote:
Hmm
Only 18 months, although was back out in it for the first time today. Yes
Posted 30th Mar 2013 at 17:28
sandy
It's a long time since I used JEs, it's been CP/Omega only and Carrillo/Robson rods as WP says for the last 4 years or so. Before anyone asks, I don't sell my specials, I'm not into selling parts, they are only for my builds. I have looked at working out some middle of the road designs for a friend of mine to sell through his business, because it frustrates me not being able to offer people a solution.
The issues with the design and manufacturing quality of Wossner/PEC pistons and rods, may not always be obvious and there are alot of engines using them, that haven't flagged the risk yet. It's a long time since I've seen an XU piston from them, but I recall the intruders and pockets needed to be machined to give safe clearance. The TU ones will rub the intruder and valves quite easily unless modified and there was an example in a Saxo I read about, built up by a well known company, where the valves did rub and the company blamed the customer supplied pistons, having blatantly not done a basic dry build check to see what the clearance was like!
Here are some pics from a TU5JP4 engine sent to me last year with those pistons and rods. I centre punched through the guides to do a basic radius check and there wasn't enough clearance for the standard inlet and exhaust valves. To illustrate it to his supplier, I took this pic, which shows 65.5mm across the pocket edges (easier to pic than the radius); the valve size (31.3 std) plus the centres (35.0mm) equals 66.3 without any clearance added, so even without the transfer punching you can see it's machined wrong! The intruder is too tall as well and touches the chamber on an unskimmed head:
The rod problems are harder to illustrate, but all of these rods feature an acute stress point on the rod bolt counterbore:
That's where they always fail and I've seen the same with DP rods supplied by Cat cams recently too. People often blame the bolts, but if they've bent before breaking and the rod bore edges are diverging, it's obviously cap failure and that point on the counterbore is where it starts. Also both of those rods mentioned in the TU have excessive material in the H-section, which causes them to clash with the bottom of the bore, demanding clearance to be machined, which relaxes the block in that area causing bore distortion.
In many cases people get away with it, but if you're serious about the engines your building, it's not acceptable and for the money they're charged out at, it's shocking.
Posted 8th Apr 2013 at 08:15
pugheaven
Post #35
Just so ppl know, Tom aka binka only had standard rods fitted when It bent a rod.....
He was told they were pec rods but in reality they were standard 6 items!
Posted 8th Apr 2013 at 08:35
Post #36
Unfortunately, this is true. Thumbs down
Posted 8th Apr 2013 at 09:11
Post #37
Any issues with Saenz rods Sandy?
Posted 8th Apr 2013 at 09:16
Post #38
I hope not, I've had two sets of these now and been using them since 2009. LOL
Posted 8th Apr 2013 at 09:28
clen666
Post #39
Hmm, I'm slightly disappointed. I originally requested IASA pistons (I assumed these were a better quality but personally have nothing to base that on) but was told the supplier no longer sold these, so just went with wossner.
I'm not blaming the supplier by the way, just that I should have done more research before purchasing.
Sandy, if these pistons were supplied to you for an engine build, could you rectify any errors easily enough or would you rather just get pistons from omega and sell the wossners on? (not sure how easy that will be after everyone reading this thread!)
Posted 8th Apr 2013 at 09:50
Post #40
You don't race on them, it sits in a garage, butt out!
Posted 8th Apr 2013 at 10:20
Post #41
He keeps revs right down for reliability and relies on boosted torque though. For people planning naturally aspirated builds with 8K+ rev limits this is more of a concern.
Posted 8th Apr 2013 at 10:22
Post #42
It has spent plenty of it's life on track though in that time, it's just had a rest recently that's all.
So, therefore, no I won't butt out...Razz
Posted 8th Apr 2013 at 12:35
Post #43
Trackdays aren't the same as a half hour of flat out racing, and knowing how much you cosset your car (quite rightly after what you've spent on it) I very much doubt that you really, truly cane it to the redline in every gear to 8,000 rpm for long. So I imagine your rods will outlast pretty much anything.
Posted 8th Apr 2013 at 12:44
Post #44
This is true to a point. I do cane it to 8k on occasions, but as you say it's not prolonged and constant. Hopefully they will last for many more years to come. Thumbs up
Posted 8th Apr 2013 at 17:02
pete_rallye
Post #45
Omega told me they don't do one off's anymore and you had to buy a minimum order of x sets. Can't remember how many it was though.
Pug1off use Wossner pistons in their xu engines and they seem ok. I guess its all down to been built right, and not assuming that because it says on the box it's right, that it is. Measure everything twice, and then twice again, and don't just check it at tdc, but tdc and 15 degrees either side.
Lap of the 'ring
Posted 8th Apr 2013 at 17:22
Post #46
They may have made some changes then. I'm sure if they were all as badly wrong as the ones pictured then there would've been some spectacular failures by now.
Posted 8th Apr 2013 at 17:58
Post #47
The Wossner pistons that Rich uses are custom made to his design, not off the shelf ones. Therefore, if they're wrong, then he measured wrong. Laugh
Which, I'm sure he didn't as my engine runs sweet. Yes
Posted 8th Apr 2013 at 18:49
Post #48
Again Mr Irrelevant your post is unwarranted, the discussion is revolving around high comp naturally aspirated pistons with large intruder domes. Not, I repeat not, flat top or concave low comp items.
Posted 8th Apr 2013 at 20:27
Post #49
I have an engine coming into my possession soon with woosner pistons that will be going to a well known engine builder so I will raise these concerns Smile
Posted 8th Apr 2013 at 20:46
Post #50
I'm half tempted to do a dry build on mine soon then, I've got all the bits, just all in separate boxes! LOL
Posted 8th Apr 2013 at 20:50
