Author Subject: rear speakers
inzomatic
hello was wondering if anyone can help? not had my phase 3 long but put my own speaker head unit in as it didnt have any cd player but cant get the rear speakers to come on inside the parcelshelf they are connected up in the back but not sure if i have to cut and connect any wires from the main connector blocks that join into my head unit any help on this would be great cheers. Thumbs up
Innes drummond
Posted 5th Feb 2013 at 20:36
aaron6
Mine plugged in and played straight away. Can only assume somethings broken.
Posted 6th Feb 2013 at 15:06
swiftyboi006
May sound silly but are the speakers you put in broken? Check the plug from the parcel shelf to make sure nothings broken. If everythings fine then try the old headunit to see if everything works off that
Black p3 Love
Posted 6th Feb 2013 at 17:40
inzomatic
pretty sure there not broken but dont have the original headunit
Innes drummond
Posted 6th Feb 2013 at 22:08
osm2121
When you changed the head unit, you must have changed the conector that goes to the head unit, maybe you didnt connect the rear speaker wires. You can try conecting your rear speakers in the front, just to discard the spearkers not working, and check that conector, if its properly installed
Posted 6th Feb 2013 at 22:14
Check the plug on the wire to the car is plugged in properly then check the speakers are actuall present ?
Check your head unit isn't faded to the front speakers as well Thumbs up
Posted 6th Feb 2013 at 22:19
inzomatic
head unit isnt faded to the front and the speakers are defo there and plugged in
Innes drummond
Posted 7th Feb 2013 at 15:06
osm2121
Try measuring with a tester if any voltage is getting to the speakers.
Posted 7th Feb 2013 at 18:10
inzomatic
got my rear speakers working just needed to wire them up from the harness to my head unit thanks for the help people
Innes drummond
Posted 12th Mar 2013 at 18:27
