according to my digital vernier. the height of the head not including the cam covers. the height is 137.1
little bit baffled lol
phase 3 Hatchback V reg 5Door GTi6
| Author | Subject: help headgasket question + cams |
Teshboi1988
Regular Location: Dartford Registered: 29 Jan 2012 Posts: 131 Status: Offline |
right i measured my head. 3 to 4 times. according to my digital vernier. the height of the head not including the cam covers. the height is 137.1 little bit baffled lol ________________________________________ phase 3 Hatchback V reg 5Door GTi6 |
stan_306gti6
Are both the cam carrier faces and the head gasket face perfectly clean and free of previous gasket/debris?________________________________________ "Supercharged - 454.1bhp/317.5lb/ft"Peugeot 306 GTi-6 2000 (X), Moonstone |
Teshboi1988
yea completely clean mate________________________________________ phase 3 Hatchback V reg 5Door GTi6 |
stan_306gti6
Perhaps try another set of verniers to compare, yours may need calibrating? Best to rule them out. ![]() ________________________________________ "Supercharged - 454.1bhp/317.5lb/ft"Peugeot 306 GTi-6 2000 (X), Moonstone |
Surely its just a standard height head? You know for sure it was skimmed? ? Could be someone tell porkies to sell it on.... ________________________________________ Red GTB1756 powered Fabia VRS daily driver,LBSC Gti6 eater........Mac1 ZR R1 kit car build in progress. |
stan_306gti6
There is always that too...what makes you so sure it has been skimmed?________________________________________ "Supercharged - 454.1bhp/317.5lb/ft"Peugeot 306 GTi-6 2000 (X), Moonstone |
bas_306gti
Regular Location: Eindhoven Registered: 06 Sep 2012 Posts: 108 Status: Offline |
here a picture of a head who has been skimmed one time: |
Teshboi1988
yea definitely been skimmed, those notches u guys were referring to. mine are barely visible.... il see if i can get it re calibrated and try again n let you no________________________________________ phase 3 Hatchback V reg 5Door GTi6 |
stan_306gti6
Teshboi1988 wrote: yea definitely been skimmed, those notches u guys were referring to. mine are barely visible.... il see if i can get it re calibrated and try again n let you no Ok, keep us informed of progress. ________________________________________ "Supercharged - 454.1bhp/317.5lb/ft"Peugeot 306 GTi-6 2000 (X), Moonstone |
Teshboi1988
Post #35
had it calibrated and the hieght of my head is136.71mm recommended headgasket thickness??? ________________________________________ phase 3 Hatchback V reg 5Door GTi6 |
Post #36
Fattest you can find ![]() ________________________________________ need a part number? get on here - http://public.servicebox.peugeot.comBring on the Trumpets. |
stan_306gti6
Post #37
welshpug! wrote: Fattest you can find ![]() Agreed. ![]() ________________________________________ "Supercharged - 454.1bhp/317.5lb/ft"Peugeot 306 GTi-6 2000 (X), Moonstone |
Teshboi1988
Post #38
1.55mm??________________________________________ phase 3 Hatchback V reg 5Door GTi6 |
stan_306gti6
Post #39
That's certainly a good starting point. To be fair, the head height minimum is 136.8mm +/- 0.05mm.Therefore at your figure of 136.71mm, you are 0.04mm outside of the maximum tolerance permissible. It will be touch and go whether or not that head is reusable really. ![]() ________________________________________ "Supercharged - 454.1bhp/317.5lb/ft"Peugeot 306 GTi-6 2000 (X), Moonstone |
Post #40
std repair gasket is 1.4, if you find a 1.45 you'll be reet.________________________________________ need a part number? get on here - http://public.servicebox.peugeot.comBring on the Trumpets. |
milkyb
Seasoned Pro Location: West London Registered: 30 Mar 2012 Posts: 1,056 Status: Offline |
Post #41
Teshboi1988 wrote: right i measured my head. 3 to 4 times. Teshboi1988 wrote: had it calibrated and the hieght of my head is 136.71mm am i the only one that found this funny? |
lost4words
Senior User Location: Leicester Registered: 11 Nov 2008 Posts: 716 Status: Offline |
Post #42
no i chuckled out loud in the office and got strange looks________________________________________ Team 'No Longer A 306 Owner'Team 'VTEC' Black Honda Civic 'EP3' Type R Moonstone 306 Gti-6 - Died at 82k Black 306 HDI - Sold 08/08/2010 at 102,229 |
milkyb
Post #43
you COL'd? |
Teshboi1988
Post #44
Lol funny stuff. Anway1.55 ok or thicker need prefernce please. Wot wood u do stan ________________________________________ phase 3 Hatchback V reg 5Door GTi6 |
stan_306gti6
Post #45
A gasket 1.45mm thick will take it back to 136.96mm, so will be ok with this. ![]() ________________________________________ "Supercharged - 454.1bhp/317.5lb/ft"Peugeot 306 GTi-6 2000 (X), Moonstone |
Post #46
as above, will be within tolerance then ![]() ________________________________________ need a part number? get on here - http://public.servicebox.peugeot.comBring on the Trumpets. |
stan_306gti6
Post #47
Unfortunately, it will be a fibre gasket as Welshpug said, which whilst they are perfectly fine to use I just have a pet hate from them and much prefer the MLS design.However, saying that, in this instance you've got no choice. ![]() ________________________________________ "Supercharged - 454.1bhp/317.5lb/ft"Peugeot 306 GTi-6 2000 (X), Moonstone |
Teshboi1988
Post #48
ok cool il see what i can find...sp what would happen if you went over tolerance. say i put a 1.55mm gasket on and it was over 137? ________________________________________ phase 3 Hatchback V reg 5Door GTi6 |
stan_306gti6
Post #49
You'd be slightly down on standard compression. ![]() ________________________________________ "Supercharged - 454.1bhp/317.5lb/ft"Peugeot 306 GTi-6 2000 (X), Moonstone |
Teshboi1988
Post #50
pug 1 off can get any size head gasket multi-layered steel. ordered.if i get a bottom pulley (alloy) do u know if there is a rubber or solid? isit worth getting one to ensure timing ________________________________________ phase 3 Hatchback V reg 5Door GTi6 |
