Author Subject: 25.4 to 28mm thick AP disc swap
devere
Any AP experts about?
I currently have 25.4mm discs on my front brake set up. I want to change up to 28mm thick discs.
Now, my calipers have the clearance to accommodate the 28mm disc..
What I want to know is as long as I get the correct pcd pattern, and correct number of mounting holes, will the be a direct swap? Will they fit my current bells without any issues? They won't sit too far forward or back on my bells? I wasn't sure if they were all the same offset of mounting holes on the disc itself or not....
Posted 4th Feb 2013 at 20:24
you'll probably have to shim your caliper away from the wheel a bit if the current disk is central and both new and old discs have the same offset to the front face from the bell.
Posted 4th Feb 2013 at 20:34
devere
Ah I see that makes sense. So where the caliper bracket bolts on behind the hub brackets, it's probably going to need maybe a 1mm shim.......
Posted 4th Feb 2013 at 20:43
1.3mm in theory.
Posted 4th Feb 2013 at 20:50
