Author Subject: Fuel Empty Light.
calibra306
My empty light comes on just under half a tank and stays on.
I keep putting fuel in over the desired level so the light goes out but today i decided to go by the level to see when it would run out.
The level was just above the red section not in it.
I removed the pump and sender from spare tank and knowing it worked 100% ie it goes to red section then the light comes on during the red section.
It still did the same thing.
Would the speedo be fault?
Why would the light come on so early (dial failure on the speedo although it does move?
V6 Power!
Faster I can go the better!
Posted 30th Jan 2013 at 22:37
so does the level itself display right but the light act gay? or does the level act erratic too? have you checked the operation of the float itself?
Posted 30th Jan 2013 at 22:45
calibra306
Both light and level is off (needle is just above red when empty)
V6 Power!
Posted 30th Jan 2013 at 22:54
calibra306
Yeah float is fine on both the senders but swapped for the one i know 100% worked in other car as the one with problem ive only had a short time (sort of)
V6 Power!
Posted 30th Jan 2013 at 22:55
calibra306
V6 Power!
Posted 30th Jan 2013 at 23:14
