Author Subject: abs fault
boost
right ive had a problem with my abs for a while now could never be botherd to fix the problem until now till i took the car off the road i was wondering if i clean the abs rings up on the shaft with a dremmel would that take the light off ? or is it easier to just replace ? ive cleaned the sensors they seem to be fine another thing is sometimes when i came out on a morning mainly when it was damp the abs light would be off until i tapped the brake the abs would kick in instantly then it would be back on any ideas would be much appreciated
97 1.6 xs gti6 conversion Smile scrapped
99 black rallye ( low miles and immaculate Thumbs up ) sold
new owner of a 2001 diablo red hdi mile muncher Smile swapped
99 red rallye turbo sold then died Sad
00 moonstone 1.9d (slow)
Posted 28th Jan 2013 at 20:45
midlife
Sure it's not your fluid level?
Cool
Team 330™Cool
Team "no front end or engine"
Posted 28th Jan 2013 at 20:49
boost
defo not fluid is fine
Posted 28th Jan 2013 at 20:54
Niall
The front sensor rings can get clogged up with crap. If you get something conductive stuck in there, it could be giving out a duff signal. Or, the front rings can break and if they are dislodged, that could give a duff reading.
Alternatively, you have a bad sensor. Can be a pita to get out but new ones are only £20 or so.
Posted 28th Jan 2013 at 22:58
I would imagine you have a dodgy sensor to be honest. You need to get it hooked up to a diag though to determine which one so you don't waste money replacing good sensors. Yes
Posted 29th Jan 2013 at 06:41
Niall
Or if you cant do that, unplug each sensor, put a multimeter on the pins set on ACv and then spin the wheel and you should see a voltage appear every time a raised part of the ring passes the sensor. If not, or if there is a constant non-varying voltage, it needs replacing.
Posted 29th Jan 2013 at 08:21
Good call there Niall. Yes
Posted 29th Jan 2013 at 10:30
Where are they from for £20?Thumbs up
Posted 29th Jan 2013 at 14:01
Niall
Ebay! Although your right, they do seem pricy. I bought one for my first 306 2 1/2 years ago now and i only paid £20 for it from Camberly auto factors!
Posted 29th Jan 2013 at 15:13
