displaying posts 1 to 25 of 30
Author Subject: Top end rattle
fraserd007
Hi all recently fitted a replacement 6 engine in my 205 track car as I blew the bottom end on the old one. The new engine i bought has had approx 1500 miles on it after a full rebuild. The problem I have is it sounds like the cam nearest the bulkhead is making a noise at around 2k rpm, its as if there is something loose inside. Im told the engine is a good one and been built by a reputable company im told it was Thumbs up fine before fitted. Not driven it yet only started it up but left running for around 20 mins thought it might just be a noisey lifter or something but the noise doesn't change? Could anyone give me any ideas or if comment if they have had this issue?
Thanks Thumbs up
Posted 26th Jan 2013 at 18:07
24seven
Is it only at 2000rpm or does it just appear to get louder/quieter around that speed?
Posted 26th Jan 2013 at 18:11
fraserd007
No it's there at around 2k then it either goes or engine sound drowns it out. At first I thought it was heat shield or something but it all looks fine.
Posted 26th Jan 2013 at 18:15
24seven
Are you sure it's not coming from one of the injectors? Try a screwdriver stethoscope to see if you can better pinpoint where it's coming from on both the inlet and exhaust side.
Posted 26th Jan 2013 at 18:42
fraserd007
Will do thanks. Just hope it's not terminal!
Posted 26th Jan 2013 at 18:50
I would imagine it is a heatshield possibly, the small one which attaches to the exhaust cam cover. As 24seven says, use a screwdriver to further pinpoint where exactly it's coming from.
Posted 26th Jan 2013 at 18:53
fraserd007
I'm going to,I've already removed that heatshield to see if it was that but no change.
Posted 26th Jan 2013 at 19:02
Is there definitely no noise at idle, apart from what should be there?
Posted 26th Jan 2013 at 19:47
ryangti6
Also check the vacuum pump as I've seen one or two of those make some nasty noises.
You may need to take it for a drive to get the lifters to fill properly, I've read a few threads on here similar and experienced it myself where the lifters won't quieten down till its had a half decent run.
Ryan
Posted 26th Jan 2013 at 20:55
This this this this this.
Mine is the same, I tighten it and it usually loosens itself a few thousand miles down the line!
Posted 26th Jan 2013 at 21:01
Eliotrw - He says he has removed the heatshield to eliminate it and the noise is still there.
Posted 26th Jan 2013 at 21:10
Fair enough, Might not be that easy then.
Perhaps the main heatshield is falling slightly...
Posted 26th Jan 2013 at 21:39
fraserd007
Thanks guys will report back.
Posted 26th Jan 2013 at 22:22
mikefish1
Try the flange from the centre pipe to the manifold as i had the same problem with mine and replaced the flange kit and job done Smile
Posted 27th Jan 2013 at 11:17
fraserd007
Right checked the vac pump thats tight,checked the plugs they are tight,no heatshields touching,nothing touching that shouldnt etc. Good call on the flange gasket i will get a replacement tomorrow
,i expect if its worn then the metal on metal sound could travel making it sound like rear of engine!! Ive noticed the noise only appears once the engine is upto temp......
Posted 27th Jan 2013 at 21:37
mikefish1
Yeah that's exactly what i imagined as the noise sounds like its coming from the engine from sitting inside the car. But metal on metal will make it sound like that. Very easy to do also but when you take the flange off check the cross section up inside the manifold to make sure its not cracked or broken as that will also have the same effects.
Posted 27th Jan 2013 at 21:56
fraserd007
Cheers will do mate.
Posted 27th Jan 2013 at 22:00
mikefish1
Let me no how it goes mate
Posted 27th Jan 2013 at 22:18
scotzman
bottom endNo
Posted 27th Jan 2013 at 22:23
fraserd007
Bottom end is not the problem I know that much!
Posted 28th Jan 2013 at 11:56
mechanical_repairs
Check the cam pullies as the early three bolt fixing ones have been known to crack and cause a noise just before self destruction.
Carl
Posted 31st Jan 2013 at 20:18
fraserd007
Thanks checked that also, everything looks fine apart from the vac pump when i put a screw driver to it and my ear,im sure the noise is from there! Does anyone do a blanking plate for it? Would the brakes be ok with just the manifold vac? thanks
Posted 1st Feb 2013 at 19:52
The vacuum pump is a common place for rattles, they have been failing for years. Yes
Posted 1st Feb 2013 at 21:50
Am i the only person with GTi-6 hypochondria?
Everytime I see one of these I'm like SO THATS WHAT THAT NOISE IS!
Posted 1st Feb 2013 at 22:11
You are the new Justin Accurate. Yes
Posted 1st Feb 2013 at 23:46
