Author Subject: Map Sensor
speedo306
Hi I need some advice.
I replaced map sensor on the right (BOSCH 99 05 25 3A/0 261 230 03) nozzle that goes down into the intake broken off with sensor on the left (BOSCH 00 08 14 3B/0 261 230 057) can this other sensor be used or do I need to get the exact replacement.
RJ
Posted 20th Jan 2013 at 12:34
Im a bit confused at what you are saying.
But if it helps there are two kinds of map sensor and they each use a different connector so arent interchangable.
I have a working one for a phase 3
Posted 20th Jan 2013 at 12:36
speedo306
The two mentioned sensors carry the same connector. The only difference is the BOSCH numbering what I would like to know is if it will work with the engine.
RJ
Posted 20th Jan 2013 at 12:43
