Author Subject: Lambda.
mattgti6phase2
Hi guys just a quick one.
Just recently my car has had a lambda issue. Pug planet says permanent O2 sensor fault. I've changed it for a brand new Bosch one which might i add only cost £43 all I'm Big grin anyway plugged it in to diag it works then chucks the fault up again. There are no breaks in the wiring at all.
I'm now thinking ECU temp sensor fault? Causing the car to over fuel therefore causing the lambda to have a fit? Any advice welcome many thanks.
Team Nile 6 Superman
Team: 40.2 MPG Smile
5 x a 306 owner!
I truely live for the 306 ®
midweek madness Tee hee
Posted 19th Jan 2013 at 12:41
beez_neez_gt
What are the engine's symptoms?
Pug fee`ver,
Pick a Bogey, buy a Pug.
Posted 19th Jan 2013 at 12:47
Have you checked the wiring for continuity then?
Also, how is the car behaving, using a lot of fuel/smoking etc?
mattgti6phase2
Yes mate checked the wires for continuity. Also the lamda reads and works for a few mins then when the car warms up it chucks the fault up again.
Just runs rich mate.
5 x a 306 owner!
Posted 19th Jan 2013 at 13:00
CTS is the next point of call then. Yes
Use the data from Autodata to measure it's resistance.
Posted 19th Jan 2013 at 13:07
mattgti6phase2
Just changed the CTS. Where as before it would make no difference if I unplugged it now it runs fast idle when unplugged.
I'd assume the CTS was also at fault. Will get on back on diag ASAP.
5 x a 306 owner!
Posted 19th Jan 2013 at 14:38
Sounds good. Thumbs up
Let us know how you get on. Cool
Posted 19th Jan 2013 at 19:13
mattgti6phase2
Since I've changed the CTS the car looses complete power then you press the throttle hard and nothing. Then all of a sudden the power will come back. I'm now confused, I put the old CTS back in and it's still the same so i dunno.
5 x a 306 owner!
Posted 19th Jan 2013 at 23:24
Hmm
That sounds more like a lambda or a MAP fault than the CTS causing an issue. What sort of revs does this new problem occur at Matt?
Posted 20th Jan 2013 at 08:24
mattgti6phase2
Low rpm bud. MAP sensor is fine as is IAT sensor Crazy
5 x a 306 owner!
Posted 20th Jan 2013 at 09:02
Low RPM deffo sounds like a lambda fault mate, despite the fact you've already changed it twice and checked the wiring. Maybe it's time to look at the data for the TPS. A fault with this would cause the lind of symptom you describe. Yes
Posted 20th Jan 2013 at 09:28
mattgti6phase2
Interesting Hmm
The thing the draws me away from the lambda being at fault is when the last one died the car never behaved like this. The fault is intermittent and when it occurs no matter how hard you press the throttle nothing will happen and then with no warning it'll spring in to life again. It will also sometimes violently shake the car to.
5 x a 306 owner!
Posted 20th Jan 2013 at 10:19
daver6
I had the same issues with mine. Low rpm, part throttle and its like the fuel pump turns off, just dies. Let off throttle and it comes back.
I swapped my MAP and lambda and haven't had the issues again
Wishbone Polybushes available
Posted 20th Jan 2013 at 10:28
honestly3k
If you wana try my MAP sensor mate I'm only a stone throw from you....you could check how filthy Marilyn is. She has icicles hanging off her bumper it really is impressive LOL
Posted 20th Jan 2013 at 10:32
Marilyn...Laugh my ass off
Posted 20th Jan 2013 at 11:25
I would recommend trying a known good MAP and TPS to try and eliminate them, so if you can meet up with Honestly3k it would at least rule them out.
Posted 20th Jan 2013 at 11:27
mattgti6phase2
I have a spare CTS in the garage that i could swap over. So will look at that when i finish work. As for the MAP sensor is it continues Chris I'll pay you and Marilyn a visit LOL
Is there a way of testing my spare CYS before i bother to install it?
5 x a 306 owner!
Posted 20th Jan 2013 at 11:35
If you can find out the resistance values from Autodata, you should be able to determine whether or not it's a serviceable item Matt. Thumbs up
Posted 20th Jan 2013 at 12:18
daver6
Engine coolant temperature (ECT) sensor
Checking - Fig. 18
Technical Data
Temperature Resistance
10°C 3530-4100 W
20°C 2350-2670 W
30°C 1585-1790 W
40°C 1085-1230 W
50°C 763-857 W
60°C 540-615 W
80°C 292-326 W
90°C 215-245 W
Ensure ignition switched OFF.
Disconnect ECT sensor multi-plug.
Relieve residual pressure in cooling system.
Remove ECT sensor from engine.
Immerse ECT sensor probe in coolant of specified temperature.
Check resistance between ECT sensor terminals.
ECT sensor may be checked in situ if engine temperature and resistance readings are compared.
Posted 20th Jan 2013 at 12:41
