What do you think is best? Injectors in the bodies or in the manifold?
I was thinking manifold so the spray onto the valve?
| Author | Subject: Injector placement |
staley_306
Regular Location: Leicester Registered: 12 Nov 2011 Posts: 238 Status: Offline |
With a modified standard inlet, ITB's can be fitted and the original injector position can be used.What do you think is best? Injectors in the bodies or in the manifold? I was thinking manifold so the spray onto the valve? |
both ![]() ________________________________________ need a part number? get on here - http://public.servicebox.peugeot.comBring on the Trumpets. |
and maybe some pointing into the trumpets too...________________________________________ need a part number? get on here - http://public.servicebox.peugeot.comBring on the Trumpets. |
staley_306
If only! |
swiftyboi006
And into the exhaust manifold for the fun of it________________________________________ cherry p1.....SOLD (regreting this)blaze p2.....why did i buy this SOLD Black p3 |
You need to speak to someone who has done the research and dyno time to qualify where to put them, your engine spec would help, with a standard road engine its probably not worth it.I know Sandy brown has played around with various injector positions on a very high powered TU engine, and has run twin setups on the XU but don't know how much time he has been able to put into the various locations and what works. ________________________________________ need a part number? get on here - http://public.servicebox.peugeot.comBring on the Trumpets. |
