Team Peugeot Sport 308 Gti�Black T'99 Gti - may she rest in peace - written off in a shunt on the A329m
| Author | Subject: driveshaft causing vibrations? |
darkgti6
Seasoned Pro Location: Bracknell Registered: 07 Jun 2008 Posts: 1,361 Status: Offline |
Could a knackered cv joint cause vibrations which feel like unbalanced front wheels? Getting vibrating at motorway speeds. Ive been getting a few clonks and clicks from the offside shaft. Only really when I instigate it by going full lock right on a hill, pulling away and allowing the car to then stop and roll backwards. Getting some awkward sounding clonk and click everytime?________________________________________ Team Peugeot Sport 308 Gti�Black T'99 Gti - may she rest in peace - written off in a shunt on the A329m |
stan_306gti6
It could either be that or the halfway bearing on the offside shaft faulty...________________________________________ "Supercharged - 454.1bhp/317.5lb/ft"Peugeot 306 GTi-6 2000 (X), Moonstone |
swiftyboi006
Could be a couple things together id just get the car up and have a look youself before anything. Check the wheel for movement, then take it off and inspect everything. Check the balancing weights are still on the wheel then go over everything. Check the ball joints, driveshaft, bushes everything. Even check for excessive engine movement. I had almost exactly this with the clunking and it turned out to be the top engine mount________________________________________ cherry p1.....SOLD (regreting this)blaze p2.....why did i buy this SOLD Black p3 |
beez_neez_gt
I think we have this on the 106, the steering wobble isnt the same as unblanced wheels its more of a subtle wobble. Going around 50 mph and i can hear the driveshaft make noises but not below that speed.I think it is the driveshaft on yours, i checked mine and movement is there at the hub side of the driveshaft. ________________________________________ Pug fee`ver,Pick a Bogey, buy a Pug. Black 306 GTI 6 Standard, was 60k mileage, bargain!! Clicky: [url =http://www.306gti6.com]click here[/url] remove the space between [url & = |
monty-69
Senior User Location: Colne Registered: 02 Jul 2006 Posts: 792 Status: Offline |
On diesels i have seen the spring fail in the offside driveshaft inner joint |
rich306
Seasoned Pro Location: Portsmouth Registered: 09 Aug 2009 Posts: 1,834 Status: Offline |
Recently travelling in a transit van, the Driveshaft gaiter had gone on it causing the Grease to flick everywhere inside the wheel arch, Thus causing the vibrations. ________________________________________ Richies Project RallyeElectrical work carried out in Portsmouth jamiek_uk2000 wrote: - Top Tip!!! You'll need to throw money at the car. Not on parts. Just stand near your car and throw loose change at it, I find this increases performance for a short period of time |
stan_306gti6
Yes, once the grease has been thrown out of the joint the joint will run dry and wear at a very fast rate causing vibrations and then failure.________________________________________ "Supercharged - 454.1bhp/317.5lb/ft"Peugeot 306 GTi-6 2000 (X), Moonstone |
beez_neez_gt
What happen when it fails so i know what to watch out for lol.________________________________________ Pug fee`ver,Pick a Bogey, buy a Pug. Black 306 GTI 6 Standard, was 60k mileage, bargain!! Clicky: [url =http://www.306gti6.com]click here[/url] remove the space between [url & = |
stan_306gti6
There is usually a loud bang and then the car won't drive anywhere. You can have it in gear and let the clutch out and the car will just sit there...________________________________________ "Supercharged - 454.1bhp/317.5lb/ft"Peugeot 306 GTi-6 2000 (X), Moonstone |
beez_neez_gt
Yeh i thought as much just didnt expect a large bang too.________________________________________ Pug fee`ver,Pick a Bogey, buy a Pug. Black 306 GTI 6 Standard, was 60k mileage, bargain!! Clicky: [url =http://www.306gti6.com]click here[/url] remove the space between [url & = |
beez_neez_gt
worst case is the broken bit flails about taking out a brake line.________________________________________ need a part number? get on here - http://public.servicebox.peugeot.comBring on the Trumpets. |
stan_306gti6
welshpug! wrote: worst case is the broken bit flails about taking out a brake line. Nothing like cheering you up... ________________________________________ "Supercharged - 454.1bhp/317.5lb/ft"Peugeot 306 GTi-6 2000 (X), Moonstone |
