Author Subject: Cooling Fans
jaybo
Hi Guys,
High speed fan doesnt work even when aircon button is pressed?
Is it easy to wire it up to a fused switch and get rid of the relays? i cant see any wires.
or is their a way to get them to work on air con switch, help needed!
Thanks
307 HDI - Everyday Car
306 GTi-6 - Road/Track Diablo Red soon to be white (T)
306 GTi-6 - China Blue (W) Sold
306 GTi-6 - Blaze Yellow (P) Sold
Posted 13th Jan 2013 at 12:40
Rich E Forum Admin
Both fans should run together, either both at low speed or both at high speed.
What happens when you unplug the brown coolant sensor? With the fan system functioning correctly both fans should come on at low speed for a few seconds and then switch to high speed.
Does your A/C work? If it doesn't then the button won't do anything. You can rig the A/C pressure switch to bring the fans on with the switch if the A/C doesn't work, but there really is no need. The standard fan system, when working correctly, is more than adequate.
Posted 13th Jan 2013 at 15:20
jaybo
Only the one fan ever comes on??
Posted 13th Jan 2013 at 15:41
the other one is broken or you have wiring or relay issues then.
Posted 13th Jan 2013 at 15:51
jaybo
Would u suggest new fans?
Posted 13th Jan 2013 at 15:57
A working fan motor swap will short it. Got one you can have if you want to take that route.
Posted 13th Jan 2013 at 16:03
jaybo
How do you get to them?
Posted 13th Jan 2013 at 16:24
