Author Subject: Head Unit Hole
mellowr1
Morning chaps.Thumbs up
Im now onto my next little task to sort and its the squeaking head unit in the dashCrazy
My car has a Kenwood head unit fitted but it does not have the peugeot triangular ended face plate thing fitted and it squeaks over bumps. I took the kenwood faceplate off and noticed the hole in the dash is slightly bigger than the kenwoods mounting cageUnsure
Does anyone know if i get a triangular ended standard faceplate thing will make my head unit fit better and illiminate one of the annoying squeaks as im sure most of you have non standard head units Dunno
cheersThumbs up
Posted 5th Jan 2013 at 12:15
darzmat
i think any time an aftermarket head unit is fitted it just goes on the rectanguar hole. the "triangular ended face plate thing" is part of the standard head unit from what i remember
Posted 5th Jan 2013 at 15:47
scotzman
I think these aftermaket adapter things do make it slightly tighter as they slot into the hole then the radio slots into that.
Posted 5th Jan 2013 at 15:53
Standard surround clips on to the headunit so you'll definately need to bodge it or buy the aftermarket facia filler.
Posted 5th Jan 2013 at 18:32
mik
I have a Blaupunkt unit in my car and it was no probs fitting it. The slot, the cage and and the head unit will all be compatible DIN dimensions so should be able to be made to fit properly. A filler piece from Autoleads goes between the cage and the dash, but it looks a bit nasty and relies on the cage to hold it in place so I don't think it would fix any fitting problem. Best to get the cage fitting correctly by making sure bent lugs are holding it in place or get a new cage for pennies on ebay. Is it actually a Kenwood cage? Is the had unit properly clipped into the cage? If not could be the problem.
Look carefully and work out whether it is the head unit moving in the cage, or the cage moving in the dash, pulling it out of the dash and refitting if necessary. Then go from there.
Top tip: before removing the head unit, put 2 layers of masking tape on the fascia around the head unit, as the back of the radio has sharp corners and will scratch the **** out of your fascia very easily when you are lining it up to put it back in.
Cherry Rallye SOLD
Posted 5th Jan 2013 at 23:29
woody.
Does you headunit have a hole in the back where a bolt would go in? In the back of my alpine unit it has a bolt sticking out that fits into a little square hole in the bulkhead. Have a look at the bulkhead through the headunit hole with a torch and u should see it. HTH
Posted 5th Jan 2013 at 23:56
just fit a supercharger, you wont hear the squeeks then
andrew315rawson@live.co.uk
Moonstone phase 7 gti6
Posted 5th Jan 2013 at 23:59
Is that how Katie rolls? No squeaks...
Posted 6th Jan 2013 at 01:48
She squeeks, skwarks and screeches al day long, gets on my tits
Posted 6th Jan 2013 at 11:58
mellowr1
ok men,thought id show ya what i gotSmile
this is it with faceplate on
this is the cage sat in dash hole.notice gap at top and cage bent up to bridge gapUnsure
right hand side is straight and shows the small gap between unit and dash
Not sure if its genuine kenwood cage as only just bought removal tools but i would hope it is.il check the bolt in the rear once i pull it out hopefully next couple of days if i get timeThumbs up
Posted 6th Jan 2013 at 16:25
Niall
My kenwood is the same. Rattles about all over the place. I wrapped the cage in body work tape and jammed it in there and that stopped it for a bit but problem is it soon starts to rattle again.
Posted 6th Jan 2013 at 20:44
24seven
Can't say I've ever had a rattly head unit with either the Alpine I had in my XS or the Sony I have in my '6 now. Are you sure the cage is pinned in place with the little bendable tabs properly? Maybe kenwood stuff is just a little smaller...
Posted 9th Jan 2013 at 00:34
