£5,200
1996 Peugeot 306 challange rally car
  • 2000cc
  • White
  • 25,000 miles
  • No tax
  • No MOT
  • Service history unknown
  • Cambelt changed: Unknown
Modifications: 306 challange rally car
Contact: 07979241124
Author Subject: 1996 Peugeot 306 challange rally car
eax81k
Peugeot 306 challenge car
Engine
2.0 16v gti6 engine with gems remapable ecu running on standard inlet manifold 190 bhp, with a helix paddle clutch and pressure plate and comp engine mounts
Cup Gearbox
BE3 gearbox with 4.8 CWP and trans-X plate LSD, rebuilt December
Genuine 306 drive shaft four only four events old
Rose jointed heavy duty gear linkages
Brakes
Bias pedal box genuine Peugeot sport with ap master cylinder only 1 even old
alcon racing 4 pot front callipers with bell and disc only three events old mintex 1166 pads, 40 miles
22mm 306 GTI-6 rear callipers, DOT 5.1 fluid, Aeroquip lines through car, Aeroquip lines from boot
Hydraulic handbrake with ap bias valve to back brakes.
Suspension/Steering
Bilstain coil over on front with 300pound springs inserts wear reconditioned two evens ago
Jumbo bilstain shock on back reconditioned two events ago
sub frame seamed welded and streighted
Solid mounted rear beams with 22 mm torsion bars and heavy duty antiroll bar
306 steering rack only 3 events old
ROSE jointed antiroll bar
Group a wheel nuts and studs
Shell
Built from a brand new shell by Peugeot sport them selfs
Seam welded shell with double skin plates on top mounts and pedal box plates
Extra gussets in engine bay
New front wings
Custom cage multipoint weld in cage with rear x and belt bars, x door bars, roof bar, main hoop braced to exhaust tunnel and rear cage legs, rear legs mounted to rear beam mounts and tagged to shell at 'A' posts, 'B' posts and roof
Alloy tarmac sump and 2 piece tank guards Peugeot sport
Welded seat rails and sill stand tubes
4mm mud flaps
Interior
Motor drive side mount seats on corbeau mounts
trs 4 point 3" harnesses, new January
Map light
Spare wheel strap
Full Peugeot sport wiring loom with diagrams etc
fuel gauge
oil pressure gauge
fuel pressure gauge
volt gauge
Oil pressure warning light
Carbon panel
Fuel lines are Aeroquip throw out
Plumbed in 2.25ltr electrical extinguisher, 1.75 hand held extinguisher, cut off switch
Aeroquip fuel lines and raised fuel pump cover
dry cell battery behind passenger seat
Peugeot sport exhausted system
More pictures available
Any questions please call LLion 07979241124
MOT 12 months
The last four events the car has competed in it finished
First in class x1, second in class x 2 third in class x 1
Posted 5th Jan 2013 at 11:44
mariusmendelis
picture?
Posted 6th Jan 2013 at 11:27
eax81k
Posted 6th Jan 2013 at 17:46
