displaying posts 1 to 25 of 30
Author Subject: loss of power
daytime6
ive had a look in search bar for what im experiencing but cant find anything.
on Thursday my car wouldn't start first time like it usually does but after a couple of turns of the key it fires up but it idle properly n slowly builds up,when its warm its fine an starts up straight away but noticed it doesn't pull like it should when you get over 4,000rpm an seems like its holding back.
ive fitted a new i.c.v an that's helped a little but but still wont start first time in the morning when its cold,have also fitted new coil packs and fuel pump relay
can anyone help me out please?
Posted 16th Dec 2012 at 19:55
honestly3k
Id be looking at the Lambda sensor fella. Do a search about it
Posted 16th Dec 2012 at 20:10
daytime6
ive not that long ago replaced my lambda as the emisions for the mot,i havent checked my air filter yet but would that give a problem as ive got standard setup with a k 'n' n replacement filter ?
Posted 16th Dec 2012 at 20:21
honestly3k
If anything a performance air filter should improve engine response as it will improve air flow.
Whats the condition of the Cat like? Its not broken up and strangled the venting of the cylinder head has it?
Coil packs would be a thought as maybe its running on 3 cylinders but you say you have tried that!
Hopefully someone with more knowledge can give you some input
Posted 16th Dec 2012 at 20:27
daytime6
ive got a magnex decat,it runs fine when its running its just when you get to 4,000rpm then it just holds back.do the cam shaft sensor give alot of grief on theses engines?
Posted 16th Dec 2012 at 20:35
Sounds like a possible MAP sensor going faulty. Yes
Posted 16th Dec 2012 at 23:30
daytime6
I've also changed the map sensor aswell,would the fly wheel sensor do anything to not let the engine run like it should?
Posted 16th Dec 2012 at 23:43
Is it a miss fire when starting from cold ?
Posted 16th Dec 2012 at 23:55
24seven
Sounds odd, but sometimes the ecu's "calibration" of the icv can go out, at least in my experience that's happened before and the car wouldn't idle at all or even start up without the throttle being open. Try disconnecting the battery for 10 minutes or so to reset the ecu, see if that clears it up temporarily while you work out what the underlying cause may be.
Posted 17th Dec 2012 at 01:06
swiftyboi006
Id go for map on this 1
Black p3 Love
Posted 17th Dec 2012 at 17:40
daytime6
I gave it a reset like you said with unplugging the battery for 10mins whilst u fitted a new map sensor but still the same takes a few times of the key to start and holding back on power Sad
Posted 17th Dec 2012 at 22:15
Ill ask again is there a miss fire when you get it started from cold ?
Posted 17th Dec 2012 at 22:19
daytime6
Sorry for not replying,na it's splutters for a second then runs fine ,I've fitted new coil packs and spark plugs ,was thinking would the fuel filter be a problem not getting fuel to the engine not letting it start like it should ?
Posted 17th Dec 2012 at 22:24
Splutters for a second from cold sounds like a possible head gasket failure ? Moisture is getting into the cylinders and stoping combustion until it clears ?
I'd get a compression test done ASAP see if everything is ok ?
Sorry to be the barer of bad news Sad
Posted 17th Dec 2012 at 22:29
daytime6
It's weird as it runs fine an pulls well up until you get to 4,000rpm which I can't get my head around,Kyle be my luck that the head gasket would be on its way out Sad
Posted 17th Dec 2012 at 22:32
playboyb
I had the poor starting issues from cold before I had the hg done on the sc6
306 1.8 xs moonstone blue-SOLD
306 gti6 supercharged china blue-SOLD
406 coupe D9 3.0 V6-SOLD
Posted 17th Dec 2012 at 22:33
daytime6
Will get one done very soon though and see if it is the hg that's gone.what are they normal bared at on the gauge when testing just to now if its ok
Posted 17th Dec 2012 at 22:36
Should be 200+ across all cylinders Yes
Posted 17th Dec 2012 at 22:39
daytime6
Ok cool cheers,really hope it's not its not hg as that's all I need right now
Posted 17th Dec 2012 at 22:41
playboyb
And a sniff test! For the sake of about £10 Thumbs up
Posted 17th Dec 2012 at 22:42
daytime6
What's one of them ??
Posted 17th Dec 2012 at 22:47
I have a compression tester bud can help you out if need be your not a million miles away either ?
daytime6
Yeah that would be handy if ya could help out
Posted 17th Dec 2012 at 22:48
Sniff test checks to see if there are combustion gases in the water system Yes
Pm me when you want to do the comp test bud Thumbs up
Posted 17th Dec 2012 at 23:08
daytime6
Ah ok farnuff,ok will do cheers Smile
Posted 17th Dec 2012 at 23:20
