I drained all of the old fluid from thefront and back brake lines before changine the front calipers. Also fitted new braded lines along with the calipers and bled the full system going from offside rear to near side rear to offside front and nearside front. Then went round again to double check i got all the air out.
Fitted the wheels and took it for a drive and the peddle is rock hard.
Basicley when you have your engine turned off and pump the peddle it goes hard, then when you start the car it goes soft again. Well mine didnt, its still hard.
There are no fluid leaks from the pipes or joints, vaccume pipe is still conected to the servo too.
Any ideas?
eddy_gti6
- (The other half's wheels)
