| Author | Subject: HU doesn't turn off w/ ignition |
24seven
Seasoned Pro Location: Derby Registered: 05 Oct 2005 Posts: 6,221 Status: Offline |
Hey folks. Picked up a 2nd hand Sony MEX-BT3600U and fitted it a couple of weeks ago, only to find the next day my battery was completely flat. I guessed it was the usual story of the red & yellow switched/permanent wires being the wrong way round so I swapped them over last night and still the head unit stays on with the ignition off. Is this just a phase 1 thing where it doesn't actually turn the HU off when the ignition is off, or is the head unit funked? ________________________________________ Ph1 306 GTi 6 | RX8 231 S1 | YBR 125 Cafe Racer | MT-03 660 |
might need to move a fuse in the fusebox iirc.________________________________________ need a part number? get on here - http://public.servicebox.peugeot.comBring on the Trumpets. |
birk
Seasoned Pro Location: Doncaster Registered: 24 Oct 2005 Posts: 7,032 Status: Offline |
My hdi does this aswell, keen to know the fix.________________________________________ Dimma + Gt35 turbo =![]() Solid rear beam mounts £130 07889376885 Dan |
smegal
See the fusebox FAX for the different fuse positions. ________________________________________ Ex SC-6Now in a Megane R26 |
Yup fuse is in the wrong position not sure which fuse it is off the top of my head but it can be moved back to its original position to sort this - proper pain in the arse if you forget to turn off the stereo and flatten the battery |
24seven
Cheers folks. will go over the fusebox tomorrow. ![]() ________________________________________ Ph1 306 GTi 6 | RX8 231 S1 | YBR 125 Cafe Racer | MT-03 660 |
Yup |
24seven
Happy days!________________________________________ Ph1 306 GTi 6 | RX8 231 S1 | YBR 125 Cafe Racer | MT-03 660 |
24seven
Also to the mods, feel free to use the picture above to replace the dead image link in the Phase 2 FAQ. ________________________________________ Ph1 306 GTi 6 | RX8 231 S1 | YBR 125 Cafe Racer | MT-03 660 |
birk
I will have to look at this, never knew it was that easy.Although my hdi is a ph3 lol ________________________________________ Dimma + Gt35 turbo =![]() Solid rear beam mounts £130 07889376885 Dan |
24seven
Looking at the P3 FAQ it doesn't appear it will be that easy for you, unless it has a P2 fuse board or something completely different again. I'm guessing you've checked the yellow/red wires already?________________________________________ Ph1 306 GTi 6 | RX8 231 S1 | YBR 125 Cafe Racer | MT-03 660 |
