cherry p1.....SOLD (regreting this)blaze p2.....why did i buy this SOLD
Black p3
| Author | Subject: What size spacers |
swiftyboi006
6j et25 off a ford rs2000 4x4 not a clue with wheels________________________________________ cherry p1.....SOLD (regreting this)blaze p2.....why did i buy this SOLD Black p3 |
as the original 6" wide wheels are ET19 you'd probably get away with none but the centre bore is too small.________________________________________ need a part number? get on here - http://public.servicebox.peugeot.comBring on the Trumpets. |
swiftyboi006
Whats the centre bore? Lol feel like such a dick________________________________________ cherry p1.....SOLD (regreting this)blaze p2.....why did i buy this SOLD Black p3 |
63.4 as opposed to 65.1________________________________________ need a part number? get on here - http://public.servicebox.peugeot.comBring on the Trumpets. |
simonjames
Seasoned Pro Location: Whitland S.Wales Registered: 23 Nov 2004 Posts: 6,219 Status: Offline |
centre bore is the hole in the centre of the wheel that sits on the hub an ET25 would need a spacer 7-10mm to achieve an ideal 15-18mm offset ________________________________________ All South Wales Members Click HereTeam Supercharged Black RALLYE ™ (Click Here for Build Project) MY EBAY ITEMS 07943066306 |
swiftyboi006
What does that mean mr welsh? I just read up on the centre bore and i understand that but if there too small what can be done?________________________________________ cherry p1.....SOLD (regreting this)blaze p2.....why did i buy this SOLD Black p3 |
simonjames
too small a bore would need the wheel machining out or a hubcentric spacer but you'd need to space past the hub so looking at 25mm+ ________________________________________ All South Wales Members Click HereTeam Supercharged Black RALLYE ™ (Click Here for Build Project) MY EBAY ITEMS 07943066306 |
Naah, you can get 15mm.________________________________________ need a part number? get on here - http://public.servicebox.peugeot.comBring on the Trumpets. |
swiftyboi006
So 15mm hubcentric spacers eill be fine? ________________________________________ cherry p1.....SOLD (regreting this)blaze p2.....why did i buy this SOLD Black p3 |
simonjames
but i doubt a 15mm would be enough to pass the 306 hub ?? ________________________________________ All South Wales Members Click HereTeam Supercharged Black RALLYE ™ (Click Here for Build Project) MY EBAY ITEMS 07943066306 |
swiftyboi006
?? So my next question would be....where do i get them? And what wheel bolts do i need?________________________________________ cherry p1.....SOLD (regreting this)blaze p2.....why did i buy this SOLD Black p3 |
simonjames
bolts would need to be longer buy the thickness of the spacer IE for 20mm a bolt 20mm longer would be needed ________________________________________ All South Wales Members Click HereTeam Supercharged Black RALLYE ™ (Click Here for Build Project) MY EBAY ITEMS 07943066306 |
swiftyboi006
Tapered?________________________________________ cherry p1.....SOLD (regreting this)blaze p2.....why did i buy this SOLD Black p3 |
simonjames
if the wheel your fitting has a tapered seat then yes, it all depends on whats on the wheel________________________________________ All South Wales Members Click HereTeam Supercharged Black RALLYE ™ (Click Here for Build Project) MY EBAY ITEMS 07943066306 |
swiftyboi006
Cheers 4 the help. So hubcentric or lugcentric spacers?________________________________________ cherry p1.....SOLD (regreting this)blaze p2.....why did i buy this SOLD Black p3 |
simonjames
i'd use hub-centric myself all you have to check is that the spacer sits on the hub with no up/down or sid/side movement and the same when fitted to the wheel, that way all the bolts are doing is tightening the wheel on if there is a loose fit when you hit a pot hole you risk breaking a bolt, i have only seen this once and that was on a BMW Z3 the guy had bad fitting 25mm spacers and a 9" width wheel and imo the threads were too short but i got a trip to Dover with his car on the back of my lorry ![]() ________________________________________ All South Wales Members Click HereTeam Supercharged Black RALLYE ™ (Click Here for Build Project) MY EBAY ITEMS 07943066306 |
