| Author | Subject: no brake lights |
aaron6
I all, I have none. Anyone got reasons why so I can work my through the possibilities? ![]() ________________________________________ See the sheer power and might of the lesser known burrowing owl. |
aaron6
If people think fuses, does anyone which one it is?________________________________________ See the sheer power and might of the lesser known burrowing owl. |
Rtfm, its in faq.________________________________________ need a part number? get on here - http://public.servicebox.peugeot.comBring on the Trumpets. |
aaron6
Rtfm?________________________________________ See the sheer power and might of the lesser known burrowing owl. |
stan_306gti6
aaron6 wrote: Rtfm? "Read The F****** Manual" I believe... By the way, I suspect it's actually your brake light switch, not the fuse, but worth checking anyways. ![]() ________________________________________ "Supercharged - 454.1bhp/317.5lb/ft"Peugeot 306 GTi-6 2000 (X), Moonstone |
aaron6
Ah nice...It's the switch I believe too. Cheers stan. ![]() ________________________________________ See the sheer power and might of the lesser known burrowing owl. |
stan_306gti6
No problem.It can be a bit of a ballache job as unless you have ridiculously small hands it's a steering column drop job. ![]() ________________________________________ "Supercharged - 454.1bhp/317.5lb/ft"Peugeot 306 GTi-6 2000 (X), Moonstone |
aaron6
Hugo has it. Hopefully he's got the time to sort it. I don't that's for sure. ![]() ________________________________________ See the sheer power and might of the lesser known burrowing owl. |
daver6
Seasoned Pro Location: Durham Registered: 08 Aug 2010 Posts: 2,379 Status: Offline |
Damn, beaten to it. probably the switch. try adjusting it before replacing.I used a pair of pliers to wiggle the switch in is housing, worked for me ________________________________________ Red Rallye - Rolling "restoration"Wishbone Polybushes available |
gilesy
Seasoned Pro Location: Greenwich - in that London Registered: 03 Apr 2006 Posts: 5,133 Status: Offline |
If you don't have child size hands then look forward to looking like you self harm by the time you are finished if you don't drop the steering wheel |
stan_306gti6
So...Did the wonder of Hugo fix it then? ![]() ________________________________________ "Supercharged - 454.1bhp/317.5lb/ft"Peugeot 306 GTi-6 2000 (X), Moonstone |
aaron6
Yep. He done a treat. ![]() He also checked my airbags on the cpu. I have a fault with pretensioner 2. Pug wouldn't say which seat it was. Any ideas as I have 2other known good pretensioners in my old seats. ________________________________________ See the sheer power and might of the lesser known burrowing owl. |
stan_306gti6
Should have unplugged one at a time whilst it was on the diag to flag up which one was faulty.I guess you could just put both your spare ones in, then you know you've sorted the issue. ![]() ________________________________________ "Supercharged - 454.1bhp/317.5lb/ft"Peugeot 306 GTi-6 2000 (X), Moonstone |
aaron6
This is true. Easy to change?________________________________________ See the sheer power and might of the lesser known burrowing owl. |
stan_306gti6
Yes mate, they are behind the B-Pillars. ![]() ________________________________________ "Supercharged - 454.1bhp/317.5lb/ft"Peugeot 306 GTi-6 2000 (X), Moonstone |
aaron6
Cool, I'll check my old seats for how to remove them then swap them once I get a chance. ![]() ________________________________________ See the sheer power and might of the lesser known burrowing owl. |
rikky
just whip the plastic casing off the side of the seat, think it's 3-4 torx bolts per side and it'll expose the pretensioner. then it's just a bolt i believe. easier with the seat out, not sure if it's as easy with the seat still in, cos you'll be working close to the tunnelcheck the pretensioner hasn't fired, it'll be noticably tugged on the wire and about an inch shorter than usual. i bought some seats once like this, never noticed until a week later when i kept whacking my hand on the seat plugging the belt in! ________________________________________ 306 rallye reproduction decals (full sets/individual decals) | 306 b-pillar textured vinyl weatherstrips306 slam panel esso stickers | 306 yellow / orange / pension fund red side door badges gti6 inlet manifold badges | 306 rear boot badges (p2/p3) winner of Extraction of toys from prams with outstanding vigour award 2009 [source: gti6 owners club] |
aaron6
Thanks for the advise mate. ![]() I'll try it whilst the seats are in. Can always take them out if need be. ![]() ________________________________________ See the sheer power and might of the lesser known burrowing owl. |
stan_306gti6
stan_306gti6 wrote: Yes mate, they are behind the B-Pillars. ![]() ![]() I just read what I wrote. For some reason I was thinking about the seatbelt rather than the pre-tensioner unit. ![]() Yes, it is exactly like Rikky says, you should manage it ok mate. ________________________________________ "Supercharged - 454.1bhp/317.5lb/ft"Peugeot 306 GTi-6 2000 (X), Moonstone |
Niall
Seasoned Pro Location: Epsom Registered: 06 Jun 2012 Posts: 1,941 Status: Offline |
stan_306gti6 wrote: stan_306gti6 wrote: Yes mate, they are behind the B-Pillars. ![]() ![]() I just read what I wrote. For some reason I was thinking about the seatbelt rather than the pre-tensioner unit. ![]() Yes, it is exactly like Rikky says, you should manage it ok mate. some cars are but not the 306. pretensioner 2 is the passenger seat i believe |
aaron6
I'll probably change both for 2 known working units. But I thought passenger seat too. Although I'd have expected just the drivers seat or both to have gone. ![]() ________________________________________ See the sheer power and might of the lesser known burrowing owl. |
