Author Subject: Locked ECU
scotzman
What's all needed to use a locked ECU?
Unit from under the dash, chip from in the key, is the ignition ring required?
Anything else?
Thanks.
Posted 9th Dec 2012 at 13:01
you only need the aerial from around the ignition barrel if its missing in the car you'll be using the ecu.
Posted 9th Dec 2012 at 13:05
scotzman
So the aerial ring isnt coded? Any ring works with any ECU?
Same with the i/r central locking sensor, is that coded?
Posted 9th Dec 2012 at 13:08
Rich E Forum Admin
ECU, immobiliser box and key chip(s) is all you need on a phase 2 as the central locking is separate.
On a phase 3 you'd need the fobs as well to retain use of the remote central locking and alarm as it's all in a combined unit.
Posted 9th Dec 2012 at 15:40
