Author Subject: Injectors
rallyedavy
Hi i think ive got an injector problem with my gti 6, when i start it from cold either first thing in a morning or after its been stood a while it misfires for the first couple of miles of the journey, its not using water/oil dosnt smoke out of the back and after a few miles it clears and drives spot on from then on until left standing for a few hours, if the injector or coil is unplugged on cylinder 4 it doesnt alterer the running at all, i thought it was a coil playing up so fitted a new coil and was still the same, anybody any ideas??
K20 0AVY!!
Posted 6th Dec 2012 at 13:58
HG going on number 4, check the colour of the plugs.
Posted 6th Dec 2012 at 14:00
rallyedavy
i did think that aswell, put a new set of plugs in and color wre fine, if it was hg wudnt it be using water??
K20 0AVY!!
Posted 6th Dec 2012 at 14:02
jammapic
I occasionally get the same problem, and I am pretty convinced my HG is going!
HDI Engine Tuning / Remapping Services - https://www.facebook.com/dervtech
306 GTi-6 Track Car - 200+ hp all N/A!
306 DTurbo Track beasty - 209.9hp - RIP
Posted 6th Dec 2012 at 14:12
it will be, it's the water weeping in overnight and it struggling to get rid of it and then it'll clear. my old 8v XSi did it for aaaaages and i knew it was the HG but just left it and eventually it started using loads. so naturally i did what any 8v owner does and i smashed it to bits and 16v'd it Wink
my hdi actually misfires from cold for about 5-10 seconds every morning doing the same thing, but again no water usage or anything. might change the glowplug thingybob
Posted 6th Dec 2012 at 14:13
more likely to be an injector rikky given its hdi.
Posted 6th Dec 2012 at 14:27
Yep, certainly sounds like the early signs of HG failure. Sad
Posted 6th Dec 2012 at 14:51
rallyedavy
Im just doin a compression test now so will see what the results are shortly.
K20 0AVY!!
Posted 6th Dec 2012 at 15:21
rallyedavy
All 4 cylinders are between 190-200 psi
K20 0AVY!!
Posted 6th Dec 2012 at 15:35
yeah, they don't leak that badly to begin with, next time you have it nice and cold, check the plugs before starting.
Posted 6th Dec 2012 at 15:44
