Author Subject: remapped GTi6 ecu for turbo
JWP EFi
Turbo Legend!
Is this actually possible?
have read about a few xsara vts turbos that are still running the Magneti Marelli ecu
Posted 25th Nov 2012 at 20:57
swiftyboi006
I dont actually know but if its been done before with a xsara then why would it be any diff with a 6?
Black p3 Love
Posted 25th Nov 2012 at 21:08
JWP EFi
Turbo Legend!
it wouldnt be any diff, IF it really does work. I just cant get my head around the std map sensor living with positive
inlet pressure, the s/c cars have the throttle body and map sensor mounted before the charger whereas a turbo has
the opposite
I'm going to phone chip wizards tomorrow to see what the man says
Posted 25th Nov 2012 at 21:13
Perhaps the ecu can accept a different map sensor?Wink
Posted 25th Nov 2012 at 21:40
smegal
On the SC-6, the map sensor (and throttle for that matter) are on the suction side of the supercharger. That'd solve it.
Ex SC-6
Now in a Megane R26
Posted 25th Nov 2012 at 21:47
smegal
Chip Wizards will tell you. Wayne knows his stuff.
Ex SC-6
Now in a Megane R26
JWP EFi
Turbo Legend!
that would be ideal, but surely if it could then wouldn't rich have done this when he developed the s/c
conversion?
Posted 25th Nov 2012 at 21:48
smegal
That is what Rich did
Ex SC-6
Now in a Megane R26
Posted 25th Nov 2012 at 21:52
JWP EFi
Turbo Legend!
really? i thought the map sensor was between the throttle and charger
Posted 25th Nov 2012 at 21:53
smegal
The throttle body is on the inlet of the charger
Ex SC-6
Now in a Megane R26
Posted 25th Nov 2012 at 22:07
JWP EFi
Turbo Legend!
yes i know that, but the sensor is between the actual compressor wheel and the throttle valve so wont
actually see positive pressure
Posted 25th Nov 2012 at 22:23
This is correct, the MAP sensor does not see boost as the standard ECU doesn't have the facility to be mapped for boost. No
The fuelling therefore is guessimated by using 'fictious' boost when using the standard ECU. Yes
Posted 25th Nov 2012 at 22:42
JWP EFi
Turbo Legend!
so based on that fact a turbo is out of the question then. But then how the feck are these xsara boys doing it?
was there not a ZX turbo on here a while back?
Posted 25th Nov 2012 at 22:45
A turbo setup where the MAP sensor would need to read boost to my mind is out of the question, therefore I don't know how they're achieving it to be honest on the 1AP ECU. Unsure
Posted 25th Nov 2012 at 22:55
JWP EFi
Turbo Legend!
iirc, GMC were rotrexing saxo vts/gti and they used a signal conditioner aka as a 'sigcon'
really wish i'd kept my pectel, so looks like i'm going to have to find an omex or something
Posted 25th Nov 2012 at 23:00
pugheaven
I'm sure some run escort cosworth loom and ecu??
JWP EFi
Turbo Legend!
thats pretty much what i had but with pectel baby board. only sold it as i had to (or so i thought) spend another
£400 for wasted spark conversion, but when guy received it he told me it already had itAngry
this is how ecosse and couple others manage there 16v turbos
Posted 25th Nov 2012 at 23:06
I have a DTA on mine, utilising a Cosworth 3-bar MAP sensor. Yes
Posted 26th Nov 2012 at 07:15
mabgti
NV motors
Better off going dta... The 1ap cant see positive boost thats why rich worked draw through setup. There is a 6ap i believe that was fitted to some euro s16s which use a 3bar map sensor... Rallying comes to mind..
Team Supercharged Gti-6
NV Motorsport
Automotive Performance Tuning
0121 448 7515
ECU Remapping/ DPF removal
www.nvmotorsport.com
Facebook Page
Project S6
Posted 9th Dec 2012 at 20:52
