Author Subject: How to remove front seat belt covering?
ben8s8
I'm stripping my 6. I've removed the rear driver side quarter panel but its stuck in there because the seat belt goes through it. How can I actually remove this and the lighter colour seatbelt cover?
Posted 25th Nov 2012 at 13:38
Undo the bolt that holds the belt by the back seat then you can feed it through the panel Thumbs up
Lift out the back seats, bolts for the belts are then visible at the sides of the car Thumbs up
Posted 25th Nov 2012 at 13:46
Rich E Forum Admin
For the front belt you need to pull the height adjuster lever off and you'll find a Torx screw behind it that removes the rest of the adjuster cover and exposes the bolt that fastens the belt to the adjuster.
Posted 25th Nov 2012 at 13:51
ben8s8
Thanks Rich, done it now.
Posted 25th Nov 2012 at 14:23
Rich E Forum Admin
No worries Thumbs up
Posted 25th Nov 2012 at 19:48
